Members stanly Posted January 25, 2014 Members Report Posted January 25, 2014 I have these glove that seem to be pretty nice and a name brand, BUT the lining keeps pulling out. I've seen other gloves with a couple stitches to hold the lining in place, but it's been done with a machine. Any ideas on how I could fix this myself? Quote
Contributing Member Ferg Posted January 26, 2014 Contributing Member Report Posted January 26, 2014 You may need to turn the gloves wrong side out to repair them. Quote
Members stanly Posted April 18, 2014 Author Members Report Posted April 18, 2014 Still have the gloves sitting on shelf... am I missing something in the above reply? Don't I still need to get inside the finger (once the glove are turned - the non lined part) to put a couple stitches through the 2 sides? (Add that this is a floating liner, not one where it's captured in the seams and has pulled loose.) Quote
Matt T Posted April 18, 2014 Report Posted April 18, 2014 You either need to remove the liner first and reattach after, sew through the liner, or repair from the outside with some advanced needle work. Quote
Members LTC Posted April 18, 2014 Members Report Posted April 18, 2014 (edited) the way i am reading his first post, his gloves aren't in need of repair. he's saying the lining comes out of the glove when you remove them because it is "floating" inside the glove...not attached to the leather part except around the wrist. just turn them inside out and put in a couple of stitches at the end of each finger through the lining and the seam of the leather to hold the lining in place. pretty easy mod. Edited April 18, 2014 by LTC Quote
Members stanly Posted April 19, 2014 Author Members Report Posted April 19, 2014 (edited) I'll have to try this, if I understand correctly you're saying to turn the fingers in a kind of "short finger" position. I've also got a cheap pair of gloves where the factory bar tacked the liner and I'll post up a pic of one if we still aren't communicating. Edited April 19, 2014 by stanly Quote
Members LTC Posted April 20, 2014 Members Report Posted April 20, 2014 i have no idea what you mean by "short finger position" what i said to do is turn the gloves completely inside out. and the liners too. then put a couple of stitches at the tip of each finger through the liner and the leather (through the seam) at the end of each finger to hold the liner in place. i am not understanding what is ambiguous in those directions. Quote
Members stanly Posted April 20, 2014 Author Members Report Posted April 20, 2014 Guess maybe I'm dense/ looking for an easy way, because only turning the gloves just seems to give the same problem only witha different material on the outside. I'll get pics up showing things, till then I'm working on patcher. Quote
Members LTC Posted April 20, 2014 Members Report Posted April 20, 2014 if you follow my directions you won't have "the same problem with a different material on the outside"...the lining and leather outer glove would be attached at the tips of the fingers. Quote
