Members ACarver Posted February 17, 2014 Members Report Posted February 17, 2014 I have cobra 4 and I have sewing lot of horse harness nicely. but now the thread is not in the center of holes, its been pulled to the right?!!!any advice is appreciated, noted that I have not changed thread size or the needle size, I use #24 with bounded nylon #207. Quote
Contributing Member Ferg Posted February 17, 2014 Contributing Member Report Posted February 17, 2014 It appears to me that your needle is too large for one thing. The type needle you are sewing with makes a hole that provides you with a saddle stitch. That stitch will of course have one thread high in the hole and one low, making the saddle style stitch. Don't know exactly why you got a straight line stitch previously. ferg Quote
Members dbusarow Posted February 17, 2014 Members Report Posted February 17, 2014 207 does work with a #24 but I usually use a #23 Looks to me like the needle is dull. Dan Quote Dan Busarow dan@fishcreekleatherworks.com http://www.fishcreekleatherworks.com/
Members wlg190861 Posted February 17, 2014 Members Report Posted February 17, 2014 Use a #23 needle Quote
CowboyBob Posted February 17, 2014 Report Posted February 17, 2014 It looks like you might be using a TRI point,try either a D or S point & it'll look alot nicer. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members ACarver Posted February 17, 2014 Author Members Report Posted February 17, 2014 thanks all for your response, I really appreciate all feedback. I'm using new ORGAN 7x4NW(Yx3LL) that been provided with my cobra 4. I have no issue like this before with same combination. its was stitching nicely. I tried to use #23 and I got stair look stitches which I don't like in long harness straps. you can see in the attached photo an old harness strap I stitched with #24 and #207. thanks again all. Quote
Cobra Steve Posted February 18, 2014 Report Posted February 18, 2014 Hello. I agree with all of the above comments, but here is another one. Make sure your needle is new and it is in straight. On another note......if you twist the needle ever so slightly, the point will enter the leather at a different angle. When you normally insert the needle, the long groove is on the left, and the scarf is on the right, like 9 o'clock to 3 o'clock, but if you twist the needle to 8 to 2, or 10 to 4, you will get a different result. If you twist it too far the machine will skip. You can try this technique on many different machines. Steve Quote Thank You Steve Tayrien Leather Machine Co., Inc. 2141 E. Philadelphia St. Unit "U" Ontario, California 91761 1-866-962-9880 http://www.leathermachineco.com cobra@leathermachineco.com
