Members JoeSnuffie Posted February 22, 2014 Members Report Posted February 22, 2014 I start by cutting the blade of a kitchen knife off, leaving about 1 inch. I use a heavy duty, reinforced cutoff wheel with my Dremel. After the blade it cut, I use my belt sander, with a 120 grit belt. I sand it down until it's about the width I want. Then I round off the taper because it looks nice. Note the bowl of water - I don't let the blade heat up too much by dipping it every few seconds. Once I'm happy with the taper, I place the blade on a 2x4 and hammer it to give it a slight bend. I hammer on the side I was cutting on because it has a couple marks where I slipped. I'm going to hit this side with the belt sander anyway. Taper the outside edge of the curve but not to a sharp chisel point - you'll just end up stabbing your fingers. This is the curve with the taper. I'm not sure if there is an ideal curve, but this seems perfect to me. I use 800 grit wet/dry paper to polish out the rough marks and make sure the tip is rounded and stab resistant. I replace the thicker reinforced cutoff wheel with a thin cutoff wheel for more precise grinding of the cutting groove. I hold the knife to the table and rotate the cutoff wheel onto the blade. This gives me pretty good control. I run the Dremel on the lowest speed and take my time. The total groove length is 1/4' from the tip while the cutting edge is set back 1/8" from the tip. Carefully work the cutoff wheel from side to side to make a wider cutting groove. Here are two sizes of bevelers. The cut like butter and are infinitely better than the bevelers I ordered from Tandy. They're a lot cheaper, too. Quote
Members Charliewz Posted February 22, 2014 Members Report Posted February 22, 2014 Thanks for posting this, Joe. I'll have to try this, they look great. Well done. Charlie Quote
Members Red Cent Posted February 23, 2014 Members Report Posted February 23, 2014 Hmmmm, I was thinking I have some old screwdrivers in the garage. Quote
electrathon Posted February 23, 2014 Report Posted February 23, 2014 When i saw you first post about this the other day I was pondering the durability of the cutting edge. After I though about it I realized that the stainless in the kitchen knife was likely far more durable than the Tandy tool edge. This is a good idea. Quote
Members humperdingle Posted February 24, 2014 Members Report Posted February 24, 2014 Hmm.. Just had a go at this. Would be rude not to use some of the cutlery we've just replaced :D Anyway, I used a fork as the neck of it seemed the ideal angle, based on what my existing beveller looks like. It cuts I used more or less the same method, but I don't own a belt sander, so used a Dremel with assorted cutting and grinding tools. It needs a bit more work, maybe a wider 'V' groove, but i'm just over the moon that I managed to make a tool that actually works! Thanks for the thread Quote
Members JoeSnuffie Posted February 24, 2014 Author Members Report Posted February 24, 2014 Glad it was useful. I thought about using the forks or spoons but with 3 kids, we seem to lose a lot more of them so when we buy more silverware we have way too many knives. Also, at least with our knives, the blades are pretty thick at the base and give a much thicker tool end than the forks or spoons would. Quote
rktaylor Posted February 25, 2014 Report Posted February 25, 2014 Thanks for sharing this idea. I think my is going to wonder where all the flatware went. Quote
Members danhux Posted August 9, 2014 Members Report Posted August 9, 2014 Great idea and great use of what's on hand. Quote
Members Dozen Posted January 18, 2015 Members Report Posted January 18, 2015 Wow thats awesome! Quote
Members JLouw Posted January 20, 2016 Members Report Posted January 20, 2016 Thanks so much for the post. What a brilliant idea. I've been in need of a #1 edge beveler for a long long time and my local Tandy stockist has not been forthcoming. So now I have a solution! I think I will actually try using a screwdriver for this. Again. Brilliant Post Quote
Members FishrOfGrizz Posted October 5, 2020 Members Report Posted October 5, 2020 None of the photos are showing up Quote
