Members FoamerAce Posted March 6, 2014 Members Report Posted March 6, 2014 Those with experience please chime in and bestow the benefit upon me. Quote
Members Dwight Posted March 6, 2014 Members Report Posted March 6, 2014 I assume that you have leather that has appendages hanging off the flesh side of your leather. First rule, . . . never buy that cheap of leather. Second, . . . take a sander to it, . . . yeah, . . . the wood sander sitting on your woodworking shelf. No sense in trying to explain how, . . . you play with it a while, . . . it'll come to you. Then you just finish the flesh side the same way you do the hair side. Now some folks don't dye the flesh side, . . . I'm not one of them. Dye jobs at my place are a baptismal effect, . . . dunked till they bubble. Add the appropriate finish, . . . I'm partial to Resolene, . . . mop & glo works, . . . as well as others. Hope this helps, . . . may God bless, Dwight Quote
Members oltoot Posted March 6, 2014 Members Report Posted March 6, 2014 First, echo what Dwight says and then for me for straps I have a very old, probably 1850's strap roller that I have put very heavy tension springs on that I roll straps through. Weaver sells newly constructed ones in some different configurations. I put cased pieces through under extreme pressure and they come out nice without a lot of work. Depending on the application, I may do additional burnishing on the edges ( while still cased) Quote
Members FoamerAce Posted March 7, 2014 Author Members Report Posted March 7, 2014 Thanks for the advise. I don't have space for a proper workshop, and wouldn't us an orbital sander in the dining room. I use a sanding block for my edges. I'll see what I can do with that. Mop & Glo eh? Definitely give that a try. Quote
Members ikewineb Posted March 17, 2014 Members Report Posted March 17, 2014 I agree with dwight about the quality of leather. I normally don't do anything to the flesh sides of straps. The one excpetion is on motorcycle bags. I will dye the back side, rub them down with gum trangnathum (however you spell that) and pull them over my burnishing stick. then I use the same top coat and sealers I use on the finished side. I only finish those because they are going to get wet. I really don't know if that process helps with water or not, but in my mind it does. Quote
Members Bicicouture Posted March 20, 2014 Members Report Posted March 20, 2014 (edited) I try to buy leather that has a pretty smooth flesh side, IF i do happen to get a piece that is kinda ugly then I coat it with Fiebings Tan Kote. I used to burnish all of the flesh side of my bags with Gum Tragacath but I applying Tan Kote is easier and less time consuming. If possible and if available try to buy a higher grade leather. Edited March 20, 2014 by Bicicouture Quote
