I've run out of my can of saddle soap that I use for my edges. before I get some more, I wanted to see which is best, The can of Fiebings Saddle Soap, or the bar of Fiebings Glycerine saddle soap?
Thanks for your help!
Bob Park's tutorial says use both
Thanks guys! I think I'll try the glycerine soap this time. I kept forgetting to put the lid on the can of saddle soap anyways!
I too use the Gylcerine bar soap. I haven't used the tin stuff so I can't compare but I get good results with the bar.
Cheers
Zip
I use liquid, daubered on. Goes on faster, burnishes very nicely. I just ordered a bar. Going to make my own liquid saddle soap with it. We make our own laundry detergent, might as well.
can the soap be purchased in local stores?
The horse goods stores sell Fiebings bar soap. Or any drug store has glycerin soap.
Depending on how much you want to buy at one time. Check the grooming section for VanDerHagen glycerin shave soap. Small pucks of soap that come in a handy (albeit cheap) plastic "conatiner" inside the cardboard display box.
Horn
Michael
"If the women don't find you handsome, they should at least find you handy" Red Green
I use the Fibiengs saddle soap in a can. Dip a rag in water, then rub it over the can soap, and wipe it on my edges. I use to buy saddle soap in the bar to clean saddles, but never used it for burnishing.
In case that's directed at my liquid saddle soap comment, I got mine at Tractor Supply. They only carry the 16 oz spray. It's made by Fiebings. Springfield leather sells it too. One thing I noticed is that the liquid is less likely to leave any color. I would get some residual yellow from the paste soap.
http://springfieldleather.com/22086/Saddle-Soap%2CGlyc%2CLiq.Spray4oz/
Wet edges, slide the bar soap across the edges to lay down the fibers, then take a piece of canvas or blue jean material and work in the saddle soap from can into the cloth or canvas then rub edges briskley until you get a slick finish. Seal with edge dressing...
Randy Cornelius
Cornelius Saddlery
LaCygne, Kansas
Randy & Riley Cornelius
Ride Hard, Shoot Fast and Always Tell the Truth...
I use a small scrap of leather instead of blue jeans/canvas and gives a nice finish as well. I am going to have to try the blue jean/canvas and see how it compares to my leather scrap. I recently ordered a cocobolo burnisher, and I can't wait to try that out.
I have went to....water. And I sand a lot. It is interesting to read about the different techniques but we are missing something. Pictures. It surprised me to read that some sand with very, very, rough grit. I have come to the conclusion that if your edge is very smooth and free of "hair", then it will burnish smoother. I discovered that if I don't sand well, the hair will come to life in form of little bumps. I sand with 220 and finish with 400. I use water sparingly because I have discovered the edge will deform.
After sanding and applying the water lightly with a dauber, the leather will be like glass after motorized burnishing. Now comes the real problem to some of us. How do you keep that super glass like look?
This is produced with nothing but water and burnishing.
Red,
I know that water produces a very nice edge. When I have experimented around water produced some of the best edges. But, they do not seem to last. A few minutes after they are done they look awesome, a little while later they are so/so. Then they do not seem to hold up. I have never tried to varnish them to see if it helps it hold up, this might be the answer.
I do agree it would be great if everyone posted a pic of the edges they got with each product.
Aaron
Why not. Cut. Sand with drum sander to square the edges. Dampen edges. Bevel edges. Light burnish with rub stick while damp. Later, wet with liquid saddle soap and burnish on drill mounted burnisher. Let dry. Rub with beeswax/paraffin mix and burnish by hand with rub stick. Finish with M&G 50/50.
Edited by chiefjason
