Members Stitch Dex Holsters Posted March 29, 2014 Members Report Posted March 29, 2014 Let us know what you think. I am curious how all of this turn out Quote
Moderator Wizcrafts Posted March 29, 2014 Author Moderator Report Posted March 29, 2014 The worse part of this is waiting on my partner's relative to do the metal work, for cheap. We still don't have the top and bottom plates made for the press. Being a shoestring operation slows you down a lot, compared to those who can afford to have things made professionally. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Moderator Wizcrafts Posted April 16, 2014 Author Moderator Report Posted April 16, 2014 We finally got the top and bottom steel plates back and installed. Our first attempts to mold blue guns, both revolvers and semi-automatics, were feeble at best. It may be due to our design technique where the back stays flat and only the front gets molded to the guns. We typically use well-soaked 8-9 ounce veg-tan tooling leather for our holsters. I will post some photos later this week (Thursday or Friday). Basically, after stacking one or two 12" x 12" x 1" pieces on top of the leather, the top-most surfaces mold well, but the trigger area is barely depressed inside the trigger guard and we cannot get the under-the-barrel/slide sides to go down anywhere near the actual sides of the guns. We have tried stacking two pieces of 1" thick 40 Durometer Buna-N and also tried 2 layers of the soft rubber from KnifeKits.com (virtually useless). I may order a couple 12 x 12 x 1" sheets of harder Buna-N (50 Du) and maybe one more 40 Du and see if that improves the molding results. We did one trial holster using some scrap 5-6 ounce veg and it molded much better than the 8-9 oz. But, that weight is useless for our designs. So far, my partner has invested about $300 in the press and top/bottom steel plates and I have purchased $100 worth of rubber sheets, with probably another $50 to $100 to be ordered in the harder/more rubber. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members SteelcityK9Cop Posted April 16, 2014 Members Report Posted April 16, 2014 (edited) We finally got the top and bottom steel plates back and installed. Our first attempts to mold blue guns, both revolvers and semi-automatics, were feeble at best. It may be due to our design technique where the back stays flat and only the front gets molded to the guns. We typically use well-soaked 8-9 ounce veg-tan tooling leather for our holsters. Wiz... Having carried everything from a Government 1911 to a Glock 27 every day for the past 19 years.... don't worry about the flat back. Most concealed carriers really like a flatter back side... it is MUCH more comfortable to carry. The last thing I want out of a carry holster is having a whole lot of pistol on the back side pressing into my hip Edited April 16, 2014 by SteelcityK9Cop Quote
Moderator Wizcrafts Posted April 16, 2014 Author Moderator Report Posted April 16, 2014 Wiz... Having carried everything from a Government 1911 to a Glock 27 every day for the past 19 years.... don't worry about the flat back. Most concealed carriers really like a flatter back side... it is MUCH more comfortable to carry. The last thing I want out of a carry holster is having a whole lot of pistol on the back side pressing into my hip I used to make my pancake holsters equally molded on the front and back. Now, they are mostly flat backed and molded on the front, if at all. We thought that a 20 ton press would speed up the molding process a lot more than it seems to be able to do. Nothing beats a strong set of thumbs and some bone folders! Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members BDAZ Posted April 16, 2014 Members Report Posted April 16, 2014 I did some work in carbon fiber fabrication and the setup we used is a vacuum table with fine perforations and then we simply lay a sheet of plastic over the item and it exerts a lot of pressure removing all excess epoxy producing a stronger item. If you were looking for a flat backed holster, I believe you would have significantly higher pressure than a simple back like device mentioned earlier in the thread. Cya! Bob Quote
