doucetjc Report post Posted March 20, 2014 I picked up a Singer 211 G 266 and would like to change the timing belt as it is cracked quite badly. In order to do this, I need to remove the pulley/balance wheel. The manual says to remove the 2 set screws on the pulley wheel and remove the pulley. I have removed the set screws, but the pulley seems to still be on solid. There is what looks to be a triangle head screw on the side of the pulley ( see picture )... is this actually a screw that needs to be removed? I have not been able to find reference to this anywhere nor have I been able to find any special tools to fit this triangle screw. Any guidance on this would be greatly appreciated. Thanks, Jeff Quote Share this post Link to post Share on other sites
Northmount Report post Posted March 20, 2014 I picked up a Singer 211 G 266 and would like to change the timing belt as it is cracked quite badly. In order to do this, I need to remove the pulley/balance wheel. The manual says to remove the 2 set screws on the pulley wheel and remove the pulley. I have removed the set screws, but the pulley seems to still be on solid. There is what looks to be a triangle head screw on the side of the pulley ( see picture )... is this actually a screw that needs to be removed? I have not been able to find reference to this anywhere nor have I been able to find any special tools to fit this triangle screw. Any guidance on this would be greatly appreciated. Thanks, Jeff Moved to leather sewing machines forum Tom Quote Share this post Link to post Share on other sites
gottaknow Report post Posted March 20, 2014 The hand wheel just has those two screws. There are no other screws involved. These hand wheels come off different on each machine. Sometimes, you can just pull it with your hand. Sometimes a gentle tap around the wheel with the wooden end of a hammer handle, and often a puller. I use a very large puller with padded jaws, tightening the puller and tapping the wheel with a hammer handle. They usually pop right off with a few turns of the puller. Regards, Eric Quote Share this post Link to post Share on other sites
doucetjc Report post Posted March 20, 2014 Thanks Eric! I had already tried tapping on it lightly, but didn't want to proceed before confirming that I didn't have to remove anything else first. Appreciate the response. Jeff Quote Share this post Link to post Share on other sites
burgermeister Report post Posted September 1 I realize I am reviving a rather old thread... Be very careful in using a puller to remove the pulley/flywheel from one of these sewing machines. I was silly and tried it following internet advice (ie, this thread), and while it worked in removing the pulley, it also jammed up the sewing machine (I have a 211U566). On my machine, the part not budging was the pulley bearing in the machine housing. So banging on the pulley with a plastic face hammer would have been the right thing to do. If the pulley is stuck on the shaft, a puller makes sense just to crack it loose. There is enough axial play around the front shaft bushing to allow parts to get bent at the needle end of the machine if a sufficiently large force is applied, such as when using a puller to remove a stuck pulley bearing from the machine housing. In my case the take up lever got bent (the hollow rod that is part of the take up lever, to be precise). It did not look out of shape to the eyecrometer, but it was sufficiently out of whack to jam up the machine. I discovered this by reassembling the machine with different parts missing until it no longer jammed up... Measuring the take up lever rod showed curvature in the rod as well as the rod no longer being perpendicular to the axis of rotation. I was able to get the shape back to where the machine runs fine, but it took quite a bit of careful work with an arbor press to get there. And obviously a lot of disassembly and reassembly. If you must use a puller, I would suggest removing all the parts that might get bent first. It's less work than fixing bent parts after the fact. Quote Share this post Link to post Share on other sites
Wizcrafts Report post Posted September 2 23 hours ago, burgermeister said: If you must use a puller, I would suggest removing all the parts that might get bent first. It's less work than fixing bent parts after the fact. This is very good advice. It might not be obvious to some people who haven't worked on disassembling sewing machines before. Quote Share this post Link to post Share on other sites
