Members ikewineb Posted April 26, 2014 Members Report Posted April 26, 2014 So, I'm looking for some ideas. I'm wanting to build a shelf / storage system for leather. Does anyone have any pictures of what they use? I'm wanting to build a shelf to store the leather flat. I was thinking of adding some side "stations" to it. I was thinking a place to set up a small sewing machine, or the like. I'm thinking of just building it from 2x4 and plywood. I'm just having touble visualizing it. Quote
Members Dwight Posted April 26, 2014 Members Report Posted April 26, 2014 Take a look at this thread: http://leatherworker.net/forum/index.php?showtopic=53478&hl=vault#entry342100 Here is the final product, . . . and I love the way it works. Only takes up a small amount of floor space, . . . I could probably hang 200 sq feet of leather in it. May God bless, Dwight Quote
Members BDAZ Posted April 27, 2014 Members Report Posted April 27, 2014 I just built a cutting table 60" x 36" out of 2x4s and plywood with the surface at 44" . I made two shelves. The bottom shelf is fixed and the top shelf slides out. The bottom shelf is for storage of rolled pieces and the top for flat. I keep untrimmed leather rolled and then flat once trimmed. Cya! Bob Quote
Members Dwight Posted April 27, 2014 Members Report Posted April 27, 2014 (edited) BDAZ, . . . that is the same size as my new work table. I couldn't put shelves under it, . . . because at both ends and one side, . . . I sit down and slide my poor old tired legs under it. Not being critical, . . . but I also cannot use your arrangement as I have a ton of sunlight pouring in my south window and door. The leather would be right in the sunlight in my shop. BUT, . . . FYI, . . . if you have a JoAnn fabric place near you, . . . they have a white poly-something plastic cutting template that is all laid out in 1 inch squares, . . . 36 X 60. The actual piece is a couple inches bigger each way for a border, . . . but if you ever do things needing some kind of quick measuring, . . . it is great. Plus it is made to be used with rotary cutters, . . . and works fine with a razor knife too. You can go on line get a 40 or 50% off coupon, . . . makes the thing about 25 bucks or so, . . . I cannot buy a better work top for that kind of money. I cleaned up the plywood I had for the top, . . . laid down several strips and a border of 2 inch double sided carpet tape, . . . woo-hoo, . . . works like a champ. May God bless, Dwight Edited April 27, 2014 by Dwight Quote
Members BDAZ Posted April 27, 2014 Members Report Posted April 27, 2014 I bought my cutting top at Hancock Fabrics for around $25 and built the table for it. I also purchased 3 yards of black vinyl and stapled it around the sides with the front a single panel which I flip over when I need to retrieve leather. Works like a champ. I have a 65mm rotary cutter for suede. Great cutting surface! Cya! Bob Quote
Members ikewineb Posted April 28, 2014 Author Members Report Posted April 28, 2014 Okay, that's pretty awesome, Dwight. I think you are right, hanging it looks like the way to go. I might hang mine a little different. I think your idea is better than mine, but it might be more than work than I want to do. I got a wall hanger system from lowes yesterday. I got a rod shelf thing that attaches to it. It has three rods, kind of like a hanging rod in a closet. I I'm going to make hangers with a swivel to hang the leather from those rods. I figured I'd take some fabric and make a curtain to go around it, to keep the sun off of it. Doing the wall hanging system, I can use it to store a lot of other items also. I'll let you know how it comes out once I get it done. Thank you guys for your input! Quote
Members Duke Posted May 14, 2014 Members Report Posted May 14, 2014 after talking to bruce johnson, and seeing what he uses, I went out an bout some shelving and concrete form tubes from lowes. slide the tubes in the shelving from the end and slide the leather in the tubes. problem solved. Quote
