Members BDAZ Posted May 16, 2014 Members Report Posted May 16, 2014 I hid a snag on a one piece strap I am making. The very end of the strap, which will be stitched into a loop is a lot spongier than I had initially thought. Must be from the neck as the strap was cut along the back. I can't reinforce the area with another piece of leather as the thickness of the leather at the loop is critical. I could possibly glue some fabric as a reinforcement and to prevent stretching or possibly use some liquid to strengthen the leather..but not sure what. Worst case I'll use cordura but I wonder if anyone has any ideas? Thanks! Bob Quote
Members RavenAus Posted May 17, 2014 Members Report Posted May 17, 2014 Not sure on the function you need the strap for but if it were me and I couldn't just do another strap and use that one somewhere else, I'd cut a new loop and attach it to the strap in a way that looked decorative enough to look like I meant it Of course, it depends on the forces you're going to put on the strap. Quote
Members BDAZ Posted May 17, 2014 Author Members Report Posted May 17, 2014 It's a banjo strap.. Cya! Bob Quote
Members RavenAus Posted May 17, 2014 Members Report Posted May 17, 2014 ... "Keep paddling, I hear banjo's!" Is about all I know about them Quote
Members BDAZ Posted May 17, 2014 Author Members Report Posted May 17, 2014 (edited) ... "Keep paddling, I hear banjo's!" Is about all I know about them That's all you NEED to know..keep paddlin' And then there's Banjo Patterson... Bob Edited May 17, 2014 by BDAZ Quote
Northmount Posted May 17, 2014 Report Posted May 17, 2014 Put a piece of fibreglass mesh like used for drywall joints between the layers, or nylon web or such. There is a thread here about reinforcing dog collars that you could search for here. Has some good comments and remedies for straps that stretch. Tom Quote
Members Troy Burch Posted May 17, 2014 Members Report Posted May 17, 2014 (edited) I hid a snag on a one piece strap I am making. The very end of the strap, which will be stitched into a loop is a lot spongier than I had initially thought. Must be from the neck as the strap was cut along the back. I can't reinforce the area with another piece of leather as the thickness of the leather at the loop is critical. I could possibly glue some fabric as a reinforcement and to prevent stretching or possibly use some liquid to strengthen the leather..but not sure what. Worst case I'll use cordura but I wonder if anyone has any ideas? Thanks! Bob a piece of corded packing tape put under there won't be seen and it will last. Edited May 17, 2014 by Troy Burch Quote
Members BDAZ Posted May 23, 2014 Author Members Report Posted May 23, 2014 I ended up skyving down the spongy part and gluing in a piece of 3oz veg tan and then stitching. On the back side, as an experiment, I glued and stitched in a piece of nylon ripstop, which made for a thinner loop. I did some tests on a similar piece and the nylon looks like a good solution. I used a hot knife to trim it so it won't fray. Barge seems to hold the nylon to the flesh side well. Cya! Bob Quote
