Members jimi Posted December 30, 2018 Author Members Report Posted December 30, 2018 21 minutes ago, shoepatcher said: One thing you may not know Jimi is the 335-17/B is a binder machine yes but it is a symmetric feed binder. To make a it that kind of binder, you must use the cover plate the moves. If not, the old plate with all the holes makes it a no binder machine or one you can install other items on that plate. Symmetric feed binders are more rare and work better. Hi Glenn, yes i did check that up after i got it, i don´t use the binder a lot at the moment but will try to leave one of the 335´s dedicated to that purpose. when you change the feed dog and needle plate to normal sewing, as i have it at the moment, i find it best with the plate off because i rest my hand or fingers sometimes on the arm and the plate will move your hand. For sure the synchronized binding feature is a plus to have underneath there when needed. Regards, Jimi. Quote
alexitbe Posted December 31, 2018 Report Posted December 31, 2018 Great work Jimi, I liked all the pictures, as they really do speak a thousand words... I am impressed with your determination and speed.. .I am a little embarrassed having done nothing with my Pfaff 193... I have taken your advice and a Pfaff 194 will be working its way to me sometime in the new year... Happy New Year... Alex Quote
Members jimi Posted January 1, 2019 Author Members Report Posted January 1, 2019 5 hours ago, alexitbe said: Great work Jimi, I liked all the pictures, as they really do speak a thousand words... I am impressed with your determination and speed.. .I am a little embarrassed having done nothing with my Pfaff 193... I have taken your advice and a Pfaff 194 will be working its way to me sometime in the new year... Happy New Year... Alex Thanks for that Alex, and hope your 194 reaches you in good condition this time. Happy new year. Jimi. Quote
Members jimi Posted January 1, 2019 Author Members Report Posted January 1, 2019 (edited) Just a quick update, I went back to the bobbin case to see what was going on with it as i found that both new and old spools from the old 335 would not fit?? so i took out the springs (tension one also) and gave them a clean and looked up the number and lo and behold it is the correct one for this machine??? On the old 335 the case just says 9075 which is referring to just the case, the number here 91 009 076 91 is for the case,latch,springs and screws. So what was the problem here? if you look at the case you can see that it has been hit a good few times each side with the needle and those two have no support under them? looks like they put in a smaller spool to overcome this problem. Tried the spool again and saw the two ends were where it was touching. Edited January 1, 2019 by jimi Quote
Members jimi Posted January 1, 2019 Author Members Report Posted January 1, 2019 (edited) So i took the pliers and carefully bent the ends out again. Sorry for the small letters here, just says can you see the difference in the gap each side? the outer side on the right is what is stopping the spool from fitting.(just click on the image a couple of times to zoom) After the ends were bent out, and old bobbin from the old 335 dropped in. And now the generic ones also fit. This was the one they put in. quite a gap there eh? Edited January 1, 2019 by jimi Quote
Members jimi Posted January 1, 2019 Author Members Report Posted January 1, 2019 I also smoothed the toe a little on the foot which was broken and hand wheeled over a few times to see how everything went..This is a 12 x 3.5 binder. Seems to go good, so i think we might have saved the Original bobbin case from it. Quote
Members shoepatcher Posted January 2, 2019 Members Report Posted January 2, 2019 Nice Jimi. It binds well. Remember, generic Pfaff feet are cheap. glenn Quote
Members jimi Posted January 2, 2019 Author Members Report Posted January 2, 2019 4 hours ago, shoepatcher said: Nice Jimi. It binds well. Remember, generic Pfaff feet are cheap. glenn Ok, Thanks Glenn. Quote
Members Jorge700 Posted July 31, 2020 Members Report Posted July 31, 2020 On 18/5/2014 at 20:49, BradR said: Tengo un 335 h2 y utilicé el manual de ajuste para el nuevo 335G y obtuve excelentes resultados. Mi máquina se ve igual que la suya pero está pintada de color verde. Suerte con ello. Hola cómo puedo conseguir el manual de la pfaff 335 h 2 Quote
Members jimi Posted July 31, 2020 Author Members Report Posted July 31, 2020 7 hours ago, Jorge700 said: Hola cómo puedo conseguir el manual de la pfaff 335 h 2 Hola, se habla inglés en el foro. por eso nadie te contesta a lo mejor?? Usas el traductor si no sabes inglés.Mandame tu email y te mando una copia, es demasiado grande para subir aquí en PDF. Send me your email and i can send you a copy. If you use the search option you will find info on the 335 in various posts that might help you. Quote
