Members DavidL Posted June 8, 2014 Members Report Posted June 8, 2014 Id like to hear everyones way of cutting a pattern out of leather. I have no issues drawing the pattern on the leather, but when it comes down to cutting the leather out I tend to cut a mm past the line on some edges and corners aren't 90 degrees on some areas. what type of tool do you use to cut rounded corners? Do you freehand or use or coin? Quote
Northmount Posted June 9, 2014 Report Posted June 9, 2014 Corner punch http://www.tandyleatherfactory.com/en-usd/search/searchresults/3780-00.aspx Tom Quote
Members Dwight Posted June 9, 2014 Members Report Posted June 9, 2014 Freehand cut everything, . . . drywall knife, . . . and I cut it on the line. All of my patterns are pretty much "on the money" so I don't have to cut extra or anything like that. The only thing I do not freehand is straps, . . . got a strap cutter for that, . . . everything else is freehand, . . . assembled, . . . sanded, . . . beveled, . . . gouged, . . . and Boss stitched. May God bless, Dwight Quote
Members Red Cent Posted June 9, 2014 Members Report Posted June 9, 2014 Drum sander is your friend. I cut the outer and liner fairly carefully but they never match up real good. After the glue is dry I square all the edges with a drum sander and a drill press. I do this with almost anything including belts. Quote
