Members Troy Burch Posted June 27, 2014 Members Report Posted June 27, 2014 Always clean your bone after use. I wash my hands beore I touch my bone. Quote
Members benlilly1 Posted June 27, 2014 Members Report Posted June 27, 2014 I am currently horrified. Lol, Ouch! Quote
Members billybopp Posted June 28, 2014 Members Report Posted June 28, 2014 Y'all keep this up and they're gonna have to move this to the adult forum. Quote
Members Chef niloc Posted June 28, 2014 Members Report Posted June 28, 2014 I advise against using household bleach on bone. The bleach will break the bone down. Maybe you won't notice much to start, but you will be limiting the life of the bone. A 50/50 mix of alcohol with acetone does a good job of cleaning. Rub with an scotch pad or fine sandpaper as mentioned above. Doubt you will return it to stark white, but you should remove enough residue to keep it from staining. Here's a good read on prep and cleaning bone: http://www.bearmeadow.com/build/materials/bone/html/bone-clean.html Good article, thanks But: makes the bone friable,[/u] but usually not for several [/u]. Museum people generally avoid bleach,Soak bone in pure bleach and you get the "magical rubber bone trick". A relatively weak solution will whiten bone, will repeated bleaching shorten the life of the bone yes. Hydrogen peroxide would definitely be my first choice but I find a 3% solution (the kind most ratably available) to be too weak to be effective and the stronger solutions (reagin grade 30%) are harder fine (get it online) but much more expensive than bleach which most people have around the house anyway. So I guess it depends on how far you're willing to go, if it's a tool with sentimental value or not replaceable then yes bleach would not be the best choice. Quote
rawcustom Posted June 28, 2014 Report Posted June 28, 2014 For other cleaning I recommend: http://www.amazon.com/Ron-Jeremy-Hardest-Working-Showbiz/dp/0060840838 Quote
