Members RavenAus Posted September 19, 2014 Members Report Posted September 19, 2014 Plus size corset in purple with silver swirls on the front panels. Size in cm as it sits on the mannequin:110 bust90 waist108 hips 8 buckles on the front panel, fully lined and edged with black suede. Quote Kind regards, Raven http://wolfscrafts.com/
Members Alvetjarn Posted September 19, 2014 Members Report Posted September 19, 2014 Looks really nice! Must be hard to make them to size as it's so many curves. BTW, you miss one rivet on the bottom right side (wearing it). Quote
Members Grey Drakkon Posted September 19, 2014 Members Report Posted September 19, 2014 Neat! I take it the silver swirls are paint of some sort? They're very subtle in the photos, which is good since it's a pretty busy piece with all the rivets and such. I see what Alvetjarn is talking about, in the second photo you can see a hole where a rivet should be right next to the bottom most strap. Quote "Everyone with telekinesis, raise my hand!" -Repairman Jack
Members msdeluca Posted September 19, 2014 Members Report Posted September 19, 2014 Beautiful, how does one go about learning to make corsets? Is there a book, or books, that you could recommend? Thanks. Quote Michael www.conceptleather.blogspot.com www.temptedthreads@blogspot.com
Members RavenAus Posted September 19, 2014 Author Members Report Posted September 19, 2014 Hi Thanks all. The silver is Tandys silver dye - https://www.tandyleatherfactory.com.au/en-aud/search/searchresults/2800-51.aspx - I oversprayed the Cobblestone dye with it and it seems to wear quite well. It's not as 'in your face' as paint would be. Those rivet holes... Yep, I did miss a couple. I actually punched a few holes I shouldn't have, I had problems sewing the edging on the Black Queen corset as I'd got rivets in the way so I'd meant to leave the ones right at the top and bottom out but didn't cover the hole in the template. Live and learn As for learning, this one's based on a Butterick pattern. Word of warning though, the stated pattern size is nothing like the finished size - make a mock up first! Also, as I was riveting this, I removed half of the seam allowance completely. If you have a machine that works better than mine you could sew it though, I'd still remove the stitching allowance from one side unless you were going to use it as a boning channel. Talking of bones, if you use anything heavier than 2mm you only really need bones if it's to be a tightlacing waist reduction corset. The leather does a good job of keeping its shape (and hers) as it is without needing bones. Quote Kind regards, Raven http://wolfscrafts.com/
Members Windrider30 Posted September 20, 2014 Members Report Posted September 20, 2014 I really love this and for some reason I really want to try and make a leather corset! Quote
Members billybopp Posted September 21, 2014 Members Report Posted September 21, 2014 Something I've always wondered .. Do you line a corset like this the entire interior area? Would you mind taking a photo of the interior, Raven? It looks great. I love the colors, and never would have thought of using the silver that way!! Bill Quote
Members RavenAus Posted September 22, 2014 Author Members Report Posted September 22, 2014 I don't have any internal pics at present, but yet I line the entire thing. Use the same pattern for the lining - either cloth or lining suede - and sew it up, clip the seams and stitch to the leather along all edges. Oh, and leave enough room between fastenings for your sewing machine! I didn't want the rivets through the lining so I put all the buckles and straps on, then had a bitch of a time getting them out of the way to sew the suede edging on Quote Kind regards, Raven http://wolfscrafts.com/
Members Airth Posted September 24, 2014 Members Report Posted September 24, 2014 Very nice work! Quote
Members brendah Posted July 15, 2015 Members Report Posted July 15, 2015 Oh look... my dimensions! I really want to try making a corset. I did find guidance on creating a pattern from scratch to fit. I ended up with some very skinny pieces. I like the way the... 2nd panel.. reaches over to the 4th panel at the top. That might address some of the issues I'm running into. Quote
Members RavenAus Posted July 16, 2015 Author Members Report Posted July 16, 2015 Brendah, this is the pattern I used - http://butterick.mccall.com/b5797-products-22969.php?page_id=916 Just be aware of the seam allowance etc I mentioned in my earlier posts Quote Kind regards, Raven http://wolfscrafts.com/
