Members Jeep1967 Posted February 28, 2015 Members Report Posted February 28, 2015 This is my first attempt at carving. I didn't practice first, just dove in. The original pattern was a bit off because I was just tracing regular paper on cased leather and the paper tended to tear. I'll get some tracing film for future projects. By the end of this project I was beginning to get a feel for walking the tools. I only used a swivel knife, lined beveler, smooth pear shader, and a modeling spoon. I can still see some of my original cut lines and I'm not sure if I just cut too deeply or just didn't bevel deep enough. Your feedback is greatly appreciated. Quote
Members ramblinrovers Posted March 1, 2015 Members Report Posted March 1, 2015 Wow. Thats the best first attempt I've ever seen! Thats REALLY good. (Mine were way worse) Keep it up and you'll be a pro in no time (which will be way ahead of me) I'm not much of an authority in leatherwork because I'm not near being a pro but I've seen a lot of the professional's stuff online Quote
Members Troy Burch Posted March 1, 2015 Members Report Posted March 1, 2015 Your leather looks too wet. Let the next piece dry a little more, you should see a burnishing effect and that is probly why you can still see some knife cuts. Good start Troy Quote
Thor Posted March 1, 2015 Report Posted March 1, 2015 I agree with Troy doesn't look like the casing process was completed. You're definitely on the right track. Quote
Members Jeep1967 Posted March 1, 2015 Author Members Report Posted March 1, 2015 Thanks for the feedback. I actually dyed it with saddle tan dye because I really wanted to see what it looked like when dyed. You can see the natural color on the right edge of the middle picture. I see what you mean about the burnishing effect. It is not as pronounced as it should be. I did a test after this piece where I cased a piece of leather and then stamped a few impressions every 15 minutes. It actually took about 5 hours of drying (well past lightening up to the original color) before I started seeing nice, dark burnishing effect. On my next try, I'll case a piece larger than my pattern and test stamp in the excess area to see when it is ready. I'd appreciate any other tips or suggestions on what and how I can do better. Quote
Members Troy Burch Posted March 1, 2015 Members Report Posted March 1, 2015 Show the next piece before you dye it, it will give a better visual for us to critique. Quote
Members Jeep1967 Posted March 2, 2015 Author Members Report Posted March 2, 2015 Show the next piece before you dye it, it will give a better visual for us to critique. Thanks! I'll be sure to do that next time. Brad Quote
Members ramblinrovers Posted March 2, 2015 Members Report Posted March 2, 2015 There see someone has to point out what's wrong before is I see it Quote
electrathon Posted March 2, 2015 Report Posted March 2, 2015 Instead of using tracing paper use regular paper just as you did, but also use a piece of plastic wrap between the leather and the paper. Also your leather was too wet. Quote
Members Jeep1967 Posted March 2, 2015 Author Members Report Posted March 2, 2015 Instead of using tracing paper use regular paper just as you did, but also use a piece of plastic wrap between the leather and the paper. Thanks for the tips. I may give it another try today using the plastic wrap and testing the leather to see when it is leaving darker impressions. I'll post the results here, if I do. And I won't dye it this time. Thanks, again. Brad Quote
