I'm with the rest -- great work!
Can you share details about how you stitched the two halves together? I'm very impressed with how close to the formed piece you were able to get without marking it. What machine and foot did you use? Any other info would also be appreciated.
Thanks,
Michelle
Edited by silverwingit
Hi there Michelle.
I have an Artisan toro 3000 machine with a 794 LR 250 needle using T350 A&E thread bought from Tippman (T300 on the bobbin).
I backstitch to start with and go up to the edge and over the edge one stitch then come back down and go around. I try and stay as close as poss without scuffing the edge. This is quite a worry when there is a big finger screw to tighten the foot up. So I modified the foot screw and couldn't find a replacement so I re-tapped the thread and put in a m4 round head machine screw instead.
This helped but it still gets in the way a little. here is a photo of the foot setup that I use.
So once I get to the other end on a (carefully marked line of course which I make with a flat screwdriver around the edge first)
I backstitch again back to the same distance down that I started with on the other side.
Hope all this makes sense to you.
Cheers
Trevor
"Way Down Under"
post-2565-0-84192100-1426285165_thumb.jp
post-2565-0-64870000-1426285182_thumb.jp
"Every Day Above Ground Is Good"
Beautiful work. If it isn't to much trouble, what do you make your molds out of?
Hi there peter.
This one was made out of some scrap particle board (not sure what you guys call it) but its cheap and easy to work. I cut a cardboard pattern first using the fold in half method to get it the same on both sides then cut the rough shape with a jig saw and then cut another the same then glued and screwed them together. I am fortunate to have a shoe makers sanding station which is a godsend. I can sand, grind and polish to my hearts content. This helps with the nice curved edges as well. the two sheets together make a good strong tall mould.
Also the outer plate or mould follower is also a 1" thick piece of the same material. its just that you need to carefully round the edges where the leather will rub under pressure. Also leave enough of a gap say 5 or 6mm all around so the leather can fold and curve up when the pressure is applied.
You can use anything that is strong like plastic board, wood and what I do like is ply wood. This is very strong indeed and will be cheap as well. I have many moulds for all shapes etc like pocket knives pouches and various shapes, but wood, particle board and plastic are all good.
cheers
Trevor
"Way Down Under"
That is some really nice work.
would love to see more of your work
Beeautiful!
That's a very good question.
The leather is quite thick (3.5mm) and will (if put under enough pressure) do what you want. The edges will ripple if you don't press hard enough and keep the pressure on for at least a day. This will help to flatten the leather as well. You can see on the first pictures that the ripples are there but not enough to worry about. Remember that this press will press 10 metric tonnes (about 11 US Tons) so its pretty good at squashing the leather. I wouldn't like to try the same thing buy hand. I think the moulds play a big part in keeping the whole lot together when squashed. keep them reasonably tight.
Hope that answers your question.
Did a double knife pouch the other day for a guy. Heres the result...
Cheers
Trevor
"Way down Under"
post-2565-0-54159600-1427105827_thumb.jp
post-2565-0-79697000-1427105841_thumb.jp
post-2565-0-29378800-1427105856_thumb.jp
