bcflyguy Posted March 19, 2015 Report Posted March 19, 2015 Hello al I have just finished redyeing my leather bags etc and want to put a few coats of Resolene. What is the BEST procedure to apply 3 coats Thank You. I know that there is a vid but not with Resolene. Thank You Neil Quote
Members Dwight Posted March 19, 2015 Members Report Posted March 19, 2015 You don't say what kind of bags or how big, . . . world of difference between a possibilities bag and a golf bag. I do holsters, purses, belts, . . . and I brush it on with a cheap, 1 inch, bristle brush bought at harbor freight. I have also sprayed it on using an air brush. Whatever you do, . . . be sure to cut it 50/50 with water first, . . . and don't get in a big hurry. May Gob bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members TomG Posted March 19, 2015 Members Report Posted March 19, 2015 Dwight, I have been using a folded rag and then even dab the rag on a paper before applying to the leather. I'm trying to avoid putting it on too thick. But maybe I'm putting it on too thin? Does the brush hold a lot like it would with paint? Quote Tom Gregory Legacy Leathercraft www.legacyleathercraft.com www.etsy.com/shop/legacyleathercraft
Members Dwight Posted March 20, 2015 Members Report Posted March 20, 2015 (edited) Actually, . . . it doesn't hold very much at all, . . . I have to go back for more, . . . I found that applying a "liberal" coat first, . . . swishing it around, left, right, up, down, . . . working up a lather of bubbles, . . . then slowly but surely in varying strokes, . . . brushing out the bubbles, . . . gives me a nice single coat, . . . that holds up well. I've taught this in leather working classes, . . . most folks catch on pretty quick, . . . dye some scraps black, . . . buff the heck out of them, . . . then try this on them. Any streaks will show up really quick, . . . and you'll be able to see how well it's doing. ALWAYS make sure your item is dry, . . . and it should be dry to use in 6 to 8 hours. May God bless, Dwight Edited March 20, 2015 by Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members silverwingit Posted March 21, 2015 Members Report Posted March 21, 2015 I personally detest Resolene for its tendency to streak, but from what I've read, spraying it on without wiping it down afterwards yields good results. Good luck, Michelle Quote
Members Paramedic04 Posted March 26, 2015 Members Report Posted March 26, 2015 I spray mine through an airbrush, 3 light coats and let it set overnight. Always cut it 50/50. I used a brush and damp sponge for a while, but I can assure that I get an even coat even better with the airbrush. Quote
Members Basically Bob Posted March 26, 2015 Members Report Posted March 26, 2015 I dilute 50/50 Wet (with water) and squeeze out a soft cotton cloth and small sponge Wrap the cloth around the sponge Dip it in the diluted resolene. Squeeze out really good Wipe softly, in one direction, across the leather. I use 2 or 3 coats, let dry for an hour or so between coats and give it a good 24 hours before messing with it. I am not set up for it right now but had excellent results with an air brush when I had access to one. Quote
Members chriscraft Posted March 26, 2015 Members Report Posted March 26, 2015 Being an ex-airbrush artist, I had plenty of airbrushes stored away so it's the only way I have applied resolene. Same as mentioned by diluting 50/50 with water. Also 3 light coats is better than one heavy coat. The first coat almost disappears instantly when applied on dry leather so try not to apply too much on this first coat. I have switched to Angelus Matte finisher and like the results better. If applied on heavy it will leave your work glossy like resolene so I just keep spraying light coats to keep the matte finish. Quote
Members Chief Filipino Posted December 29, 2017 Members Report Posted December 29, 2017 On 3/26/2015 at 0:08 PM, chriscraft said: Being an ex-airbrush artist, I had plenty of airbrushes stored away so it's the only way I have applied resolene. Same as mentioned by diluting 50/50 with water. Also 3 light coats is better than one heavy coat. The first coat almost disappears instantly when applied on dry leather so try not to apply too much on this first coat. I have switched to Angelus Matte finisher and like the results better. If applied on heavy it will leave your work glossy like resolene so I just keep spraying light coats to keep the matte finish. how does angelus matte finisher compare to resolene in regards to water resistance? Quote Halo-Halo Creations your home of culturally inspired handmade leather, calligraphy, and more. http://tinyurl.com/hhcreations
