Members georgeandgracie Posted April 6, 2015 Members Report Posted April 6, 2015 My customer wants some bags with brass luggage-style zippers, the kind with two sliders that meet in the middle of the zipper when closed. I thought I could make these myself with parts but sadly, that appears to be possible only with plastic-tooth zippers. I don't need custom sizes; I can tweak the bag dimension to fit standard lengths such as 30", 36", and so on. If necessary, I would be happy to order 10 at a time or some such quantity, but certainly not a thousand zippers. Where on earth can I find these? Google is not helping locate a source. Quote
Members Troy Burch Posted April 6, 2015 Members Report Posted April 6, 2015 I bought some brass toothed zippers and stops from Tandy a few years back, I guess they still have them. You can buy the zipper by the foot and the stops seperate. Quote
Members MonicaJacobson Posted April 6, 2015 Members Report Posted April 6, 2015 Pacific Trimming has....er... expensive Riri ones.. don't know how much help that is. And they only seem to have m4 or m6.. Quote http://monicajacobson.com/ https://www.etsy.com/shop/TrimGoTrix?ref=si_shop
Members DavidL Posted April 6, 2015 Members Report Posted April 6, 2015 O type zippers are the ones you are looking for. I think anyone that sells YKK zippers has them. A heads up, theres another zipper that has two sliders in one zipper but both run the same way, which wont work for your situation. This is just guess work (I've always used pre fabricated zips)it might be worth buying a regular zipper, buy an extra slider and install it on the other end. Im not sure if O type zippers use different teeth or if you can install a slider the other way.. I do have some backpacks that use O type zippers, it seems like its just a matter of adding another slider. Al stohlmans book has instructions on how to remove zipper teeth and add zipper stops to create a zipper with a stop to prevent the slider from going past center all while in one continuos tape. Quote
Members Troy Burch Posted April 6, 2015 Members Report Posted April 6, 2015 (edited) You can also go to a taylor shop or a place that does alterations and they will sell or order what you need. I like to use the metal zippers that are used in levi jeans. Theres a dress shop down the road from me that makes wedding and prom dresses and does alterations that orders what I need in any length, I'm sure they can order any kind of zipper made. Edited April 6, 2015 by Troy Burch Quote
Members georgeandgracie Posted April 6, 2015 Author Members Report Posted April 6, 2015 What I have learned is that this type of zipper is weird, odd, obscure, and will drive you to desperation if you want them. You cannot just make them the way you can with other types of metal zippers. With plastic teeth, yes you can, but not with metal. And no, not every zipper place has them. Also, some online zipper suppliers are abrupt and unhelpful when you email to ask. Riri zippers are twenty dollars apiece!! How does the Riri sizing system work? I understand YKK sizing: the number matches the mm width of the closed teeth. DavidL, thank you for the information that these are called O type zippers. Quote
Members georgeandgracie Posted April 6, 2015 Author Members Report Posted April 6, 2015 Here is the best response I've gotten yet from a zipper company, Supreme Zipper: "You are in need of a very particular type of metal zipper that would allow for double slider application (head to head). We carry #5 brass & nickel Excella (two-way) zipper chains that is made specifically for this purpose but have a very limited selection of tape color options. I must also let you know that this is very costly. If you provide me with more details such as length/yardage I can get you pricing." Quote
Members blue duck Posted April 7, 2015 Members Report Posted April 7, 2015 You might try wawak.com and or the buckleguy.com I got some of those from one or maybe both of them. Quote May God Smile on you today.
Members SantaFeMarie Posted April 7, 2015 Members Report Posted April 7, 2015 Ohio Travel Bag has these, possibly others as well - I didn't do an exhaustive search. Quote
Members gzvunm Posted April 8, 2015 Members Report Posted April 8, 2015 whether this kind of metal zipper you are talking about? https://docs.google.com/a/kingcamry.com/file/d/0B_9oHAG6U8szUkNNNnlpZThZRUk/edit Quote we are manufacturer of metal hardware/buckle for bag,belt,shoe in china,visit our website for more information, www.kingcamry.com gzvunm@gmail.com
