cool design but personally, using rivets instead of sewing the top flap on gives it a half thought out design since everything else is sewn.
stitching is also kind of rough. Did you use pricking irons or a stitching wheel to place them or just eyeballed it? Inside stitches look more evenly placed from the edge so maybe it was the angle of your awl going through the leather.
Edges don't look like they were burnished either
Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
even as an after thought, you could have sewn it in place
might sound odd but you could use an awl blade in a drill press to punch your holes,just don't turn it on
wouldn't need a full sized one. I have a dremel work station that use on thick leather
I use a drill press, works great. I bought an auxiliary drill press table with a fence, helps alot.
