I looked at the bronze bushings but I could not find specs as far as rpm and such, that is why I am a bit shy about them. For what is worth, I did see another member here that just slapped the 2 pulleys together and use a bolt for a shaft and did not even use a bushing (at least it appeared to me that way)... not sure how is that contraption is still working. Is that picture of your reducer and do you have a picture of the other side?
Here is a picture of one of the ball bearing reducers I made, before installation, showing the mount and adjustment areas. The bronze sleeved ones are just like it, essentially.
post-46726-0-03939600-1435425485_thumb.j
-DC
Machines: Juki LU-563, Consew 206-RB5, Singer 20U33, Pfaff 481, Mitsubishi CU-865-22, Consew 29B, Rebadged Juki LU-562,  Mitsubishi LS2-180,  Seiko SK-6, Juki LG-158-1
file:///Users/dangray/Downloads/IMG_0626.JPG
file:///Users/dangray/Downloads/IMG_0628-2.JPG
This might give you an idea of what can be made. One picture shows parts separated the other the way ti would be working. the pulleys have allen screws to fix it to shaft along with 3/16 woodruff key, on the other side of the pillow blocks there is a collar that locks shaft so it stays in place. All parts can be purchased on ebay. This setup is using 3/4" shaft.
SARK9 - those are super nice speed reducers you made - well done! I made a speed reducer similar to DannyGray for my Adler 205. It works well and no machining required, but the SARK9 version looks way nicer and is much more compact and easier to adjust. Alas, my particular configuration of the stand did not lend itself to using the compact version the machine came with when I switched to a servo motor.
Here are some pictures of my speed reducer, made from parts sourced on Amazon.com and my local Home Depot:
post-56402-0-68174900-1435469269_thumb.jpost-56402-0-09467600-1435469277_thumb.jpost-56402-0-07444600-1435469285_thumb.j
Edited by Uwe
Uwe (pronounced "OOH-vuh" )
Links: Videos
Love seeing all of y'all setups. Keep them comming!
  • 3 years later...
https://www.walmart.com/ip/Grizzly-G5436-Single-V-Groove-Pulley-6-Pitch-Dia-1-2-Bore/134318402         this is the one I bought. but I am replacing the stock hand pulley on the machine with this one. it is almost twice as big and coupled with a 50mm replacement on the motor I think it will work. will keep you posted on the results.
Edited by wydfuqnopn
Remember a old worktop standing drill, it had about 6 sets of pullies in pairs of various sizes where you moved the belt up or down and have 6 speeds to play with, maybe you guys are thinking to small with just one pair:lol::lol::lol:
Edited by chrisash
Mi omputer is ot ood at speeling , it's not me
