Just finished these guys, only problem is the resolene keeps streaking. I diluted 50/50 with water and applied a light coat, not sure what the problem is. Its very subtle but still noticeable. Any suggestions will help as I am still a beginner! Thanks!
post-62834-0-07927700-1435984496_thumb.j
post-62834-0-04940100-1435984678_thumb.j
Edited by JustinBrown8
It won't streak if you use a boar bristle brush or some other kind of cheap one and brush the bubbles out going in all different directions. Cheryl
If you have the room and access to one, get a small compressor and air brush for your resolene, you won't get any streaks that way
I like em!
Did you have to skiv the leather in order to rivet these?
Would you dilute the resoline for spraying?
I like em!
I skyved the keychain flaps but not the wallet! Thanks!
Yes, I mixed a 50/50 mixture and it's still streaking, i am going to try different brushes, so far the really dense foam brushes are streaking and so are sponges.
