Members dikman Posted August 6, 2015 Author Members Report Posted August 6, 2015 Thanks Darren, I've seen your posts/photos on the Able 290 and wondered what you used. My winder has worked out pretty well and is mounted in the same position (the only practical place to put one). I turned down the bobbin winder shaft on the lathe and then found it only fitted one bobbin! Mine came with four bobbins, and they all had a different size centre hole, so I had to drill them out slightly!! I've also made an adjustable guide to keep a consistent spacing if sewing along an edge. I really need to experiment with making a decent presser foot next. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Ole South Posted November 12, 2015 Members Report Posted November 12, 2015 What's the max stitch length on these Chinese patchers? Quote
Members Darren Brosowski Posted November 20, 2015 Members Report Posted November 20, 2015 It vary from machine to machine and can also depend on the direction you sew!! Generally I quote 6mm (1/4") What's the max stitch length on these Chinese patchers? Quote
Members IM7 Posted October 11, 2016 Members Report Posted October 11, 2016 The hand-crank machine is gritty and mean and I'm in love! I ordered mine from bantamsaddletack and it arrived quickly. I've been using it on full grain leather boots, jackets, gloves, and more. Taking hints from motorcycle maintenance, I wiped mine down with denatured alcohol, polished a few parts with Mother's Mag & Aluminum polish, and I'll be lubing the cams with a low viscosity, full synthetic oil (replacing the castor oil I have been using, whose smell I quite like). How exactly does one change the stitch length on these machines? Ole South inquired about the max length; I am interested in a shorter stitch length. I reckon' it's a real simple turn of a screw, but I'm scratching my head at which one. Please enlighten me! Quote
Members Darren Brosowski Posted October 11, 2016 Members Report Posted October 11, 2016 The screw is under the frame - below and to the left of the tension Quote
Members IM7 Posted October 11, 2016 Members Report Posted October 11, 2016 Thank you for the quick reply! Quote
Members Darren Brosowski Posted October 11, 2016 Members Report Posted October 11, 2016 Lucky I was on at the right time! Quote
Members Ardie Posted March 13, 2017 Members Report Posted March 13, 2017 Hi, I'm having tension issues.... Its a jumbled mess on the bottom. How can I tackle this problem? Quote
Moderator Wizcrafts Posted March 13, 2017 Moderator Report Posted March 13, 2017 2 hours ago, Ardie said: Hi, I'm having tension issues.... Its a jumbled mess on the bottom. How can I tackle this problem? It will help if you can post a photo of the machine and the thread mess. Without seeing what's happening, or the machine it's happening on, all I can do is offer general solutions. If the knots are on the bottom and causing the bottom thread to lay flat rather than being pulled up into the holes, either loosen the bobbin tension or increase the top tension. If there is a whole pile of thread in and around the bobbin, first, hold back the starting threads for a few stitches. Next, make sure that the top thread is feeding inside the top tension disks and not lifting out of them. Third, make sure that the bobbin thread isn't jammed tight coming out of the bobbin case. Fourth, make sure the needle is the correct size and system for the machine and thread and that it is inserted in the correct orientation and all the way up inside its mounting bracket. Make sure you've threaded the needle in the correct direction. Finally, check the timing of the hook tip to the eye of the needle as it rises above bdc and forms a loop. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members stevemaynard Posted March 29, 2017 Members Report Posted March 29, 2017 I just bought one of these and have it sewing thin leather together and thin to thick leather (3.5mm , roughly 1/8") , but when I try to sew thick to thick leather the thread snaps or is sheared off. I have tried using the waxed linen thread from a speedy stitcher as well as Getterman linen thread as well as varying the tension I have a 100/16 needle on the machine. I would prefer to use natural fibre thread if possible as I am wanting make stuff to sell to medieval re-enactors. Any thoughts or suggestions appreciated. Quote
