Members TinkerTailor Posted November 7, 2015 Members Report Posted November 7, 2015 I know if i wanted to make mine longer one way I may do it is to epoxy a finishing nail alongside of the too short pin, sticking out more.... Quote "If nobody shares what they know, we will eventually all know nothing." "There is no adventure in letting fear and common sense be your guide"
Members dikman Posted November 7, 2015 Members Report Posted November 7, 2015 fasn8ya, my Pfaff 335 didn't have a pin, it has a manual lever to release thread tension. On the advice of a member I removed the tensioning unit and lo and behold, there was a hole behind it for a pin. I found a suitable piece of rod that fitted the hole and by operating the foot lift lever I could work out how long the rod needed to be, cut it to length and I then had automatic tension release. Might be worth having a look if you can remove the tensioner (one screw on mine is all that held the plate on). Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
