Members jstar61 Posted November 13, 2015 Members Report Posted November 13, 2015 I downloaded draft sight and will have to look some more, I didn't see where I could import and stretch a drawing sure hope I am wrong. But it didn't cost anything so! You can, I do it all the time. To import, click on insert tab at the top left. Quote
Members danhux Posted December 20, 2015 Members Report Posted December 20, 2015 Inkscape and Gimp are both great, lots of tutorials on the net for both. The issue with these apps is learning to work with layers and different file types. Quote Dan Hux Raleigh, NC
Members emcniel Posted December 20, 2015 Members Report Posted December 20, 2015 I use autoCAD to get the dimension right and there are several makers of the acrylic patterns Quote
Members robbied Posted December 22, 2015 Members Report Posted December 22, 2015 Another vote for inkscape here. Use it for almost everything. Quote
Chief31794 Posted December 22, 2015 Report Posted December 22, 2015 Again Inkscape, it has all the capability I need to draw patterns and then to print them out in PDF. Has a learning curve but there's plenty of on line help and tutorials. I've used it for years to include producing .SVG vector graphics flies that I send to Black River Laser and they use them to cut my templates on the laser. Chief Quote "Life's too short to carry ugly leather"
Members Kulafarmer Posted December 24, 2015 Members Report Posted December 24, 2015 I use autoCAD to get the dimension right and there are several makers of the acrylic patterns Am leaning towards going with AutoCAD myself, used it extensively for construction detail drawings and cabinet layouts, Vowed to never buy another windows based anything so is nice that they now make a version for MAC OS, AutoCAD to me is perfect, importing drawings, scaling, resizing, mirroring details and drawing elements, plus the compatability of output to most operating software used by CNC or Water Jet or Laser cutting hardware. AutoCAD LT is reasonably affordable for a professional design product, but it isnt for everyone, personally is easy as i can do both command line or key entry, but it can be tough to learn. Quote
Members geckostraps Posted December 26, 2015 Members Report Posted December 26, 2015 Someone gave me a pen pad for Christmas. A pretty good sized one at that. What is the best software to utilize this thing? If I can trace something, that would be great I don't know much about these programs Quote
Members TinkerTailor Posted December 26, 2015 Members Report Posted December 26, 2015 You can, I do it all the time. To import, click on insert tab at the top left. Drafting programs are made to use absolute measurements to scale, and maintain these relationships accross multiple files, like in a house design. If you change one thing on one drawing it can effect unseen things in other files, especially when working in 3d. For leather patterns, they are generally all in one drawing, and this is not an issue for us, however this is how the software was built and has different methods than adobe products would for example. This means you generally can't scale and stretch things like you can in standard graphics software, You can do it, but the methodology and tools used can be quite different because the software is designed to keep dimensions in check and maintain relationships between different pieces of the design. Cad software is so much more powerful than is needed for leather patterns in 2d, Also, Cad or other vector based graphics software need to be used if you want to get the pattern laser cut for example, as Cheif has said Quote "If nobody shares what they know, we will eventually all know nothing." "There is no adventure in letting fear and common sense be your guide"
Contributing Member JLSleather Posted December 26, 2015 Contributing Member Report Posted December 26, 2015 I've seen quite a few different 'programs' used to make patterns. In the end, I wonder if some good ole graph paper isn't as good as anything Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members TinkerTailor Posted December 26, 2015 Members Report Posted December 26, 2015 I have worked with autocad for years both in my job and at home. I was tech support for an autocad drafting school. I am pretty proficient at it, and i still make all my patterns out of cardboard and glue them to masonite if i want stronger ones.I do not cut against the pattern, i cut freehand on scribed lines. I find this is faster because i can test the size of the pattern in my hands, instead of on the screen. If it is too big, just cut it in half, overlap and tape it back together. Too small and i add a biece Quote "If nobody shares what they know, we will eventually all know nothing." "There is no adventure in letting fear and common sense be your guide"
