In response to Wizcraft... If I move the needle bar forward won't I have to adjust the timing of the looper?... This grips me with fear... :(:)
Cheers
Alex
Possibly and possibly not. The looper timing should be related to the position of the eye of the needle. If you move the needle bar to accommodate a longer or shorter needle and place the eye in the same horizontal position when the looper arrives, the timing should still work.
Posted IMHO, by Wiz
Hi There alexitbe, i have a 45k49 which uses 215x15 needles, can i ask where you bought them as they seem difficult to get hold of?? and on the underside of the needle holder on this machine if i can remember correctly, there is a small stop for the length of the needle which screws out so maybe this could be to allow for longer needles?? not sure. i will take a look. jimi
Hi Jimi
Lucky you! 215x15 are used much more in the 46k series.
I got mine from College sewing in the uk. I beleive they are still on sale. They wanted to get rid of this old stock so I would buy them now if I were you.
If you have no luck I will ask around...
I hope that helps.
Alex
Hi Alex, thanks for the info. i will give them a buzz. here are some pictures i have just taken, maybe your needle bar is similar??
post-32832-0-44817400-1447706153_thumb.jpost-32832-0-53254400-1447706174_thumb.jpost-32832-0-22629800-1447706192_thumb.jpost-32832-0-55233800-1447706210_thumb.jpost-32832-0-19334800-1447706226_thumb.j
Edited by jimi
Hi Jimi and Wizcraft,
Wizcraft: On second reading I now understand what you are saying...It makes sense assuming that the bit from the hole to the point is roughly the same as the old needle. I have been sewing a patch today and see that the "needle clamp or holder" touches the body of the machine when needle is furthest away and is a couple of mm away from the feed disk edge when the needle is nearest the user. I think this means I cannot adjust the needle bar.
I think the only solution then is to go for a needle that is the same length or shorter. If shorter I can just move it a few mm forward from the back stop in the needle clamp.
I would really like to know if the needle I have is actually the 215x5 needle or not. However I don't know how to find this out. If not I would not be so anal and would just go for a period 292 needle.
Jimi: The needle clamp is much different on mine. I would like to post some pics to show you, and of the patch I have just done. However , I cannot find my USB camera attachment. :( Maybe tmrw.
Is the screw you point to the adjust for the stroke of the needle bar?
Cheers
Alex
the screw is to loosen the needle bar and the correct position (if i am not wrong) is in the other picture where the needle tip is at the first line and the looper is coming in on the needle at the second line. at least that is what i remember from the manual and it sews this way no problem. sorry but i aint got a clue if that is a 215x5 needle you got there??? if your needle is long and you cannot move it backwards, why not try the 215x15 and move it a little forwards??
  • 4 years later...
On 11/15/2015 at 7:02 AM, alexitbe said:
Hello All,
I have tried everywhere and made a few expensive mistakes so now I must get help from people who know...
I need a needle to fit my Singer 46k "fur" cup feed overseamer.
Fortunately it came with a needle already installed. It is very precious as its my only one.
The shank diameter is 1,08 mm
Length to hole 30.0 mm
Total length is about 36.6 mm
I have looked at what other overseamers use and...
None of the Bonis 292 needles fit this length. The nearest is the conu 01:30MA with a length to the hole of 27.9 mm
Tried a needle of the same period as the sewing machine (100 yrs ago)
I have bought a 12x1 needle and that does fit either.
I have looked at light industrial sewing machines and have found the following:
Canu 04:45 or 88x1
Diameter is 1.62 mm (is this going to be a problem to fit?)
Length to hole is 29.6 mm (I think this is close enough)
Should I try this one? Do you think this is close enough or can you suggest another?
Thanks for making it to the end.
Alex
post-57035-0-93265000-1447593155_thumb.j
Did the 88x1 work?
This may help when comparing needles.
The measurement from Butt to the top of the eye is what is used.
Bert.
Edited by Bert51
