Members dikman Posted January 28, 2016 Members Report Posted January 28, 2016 I'll have to ask you chaps, 'cos I'm stumped. My 211G166 has started misbehaving, and is forming loops (of the top thread) on the bottom. (#69 thread, size 18 needle, white on top brown in bobbin). It will stitch ok for 2, 3, 4, 6" and then start making loops. I've played with tension settings on the top and bottom threads, but it didn't help. I stripped and cleaned the thread tensioner and the takeup spring, all appears to be working as it should. I increased the tension and travel on the takeup spring, but it still happens. Seems to me that if the takeup spring is the problem then it should happen all the time. I tried a bigger needle (size 22) but it still happens. Not a good day, I switched to the Pfaff and now that's decided to start being stupid! Any ideas welcome. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Constabulary Posted January 28, 2016 Members Report Posted January 28, 2016 Just a guess but if that is on top I´d say thread popped out of the tension discs. You probably have to alter the angle the thread goes through the tensions discs. The thread guide is a bit odd on the 211 (at least the few I have seen) - you have to put the thread guide in an correct angle. Sometimes the angle is not flat enough. Post a picture of your tension unit please. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members dikman Posted January 28, 2016 Author Members Report Posted January 28, 2016 The loops are on the bottom. While it's stitching I've watched the thread path and it's definitely not popping out anywhere. This is why I'm puzzled, it's as if the top thread is getting some excess slack and it's pushing through the leather. I can tell by the sound when it's happening and the takeup spring stops working because there's too much slack building up after the tension disc. But why does it happen after it's already sewn quite a few stitches? Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Constabulary Posted January 28, 2016 Members Report Posted January 28, 2016 srry - I was on the wrong track - when top thread pop out of the tension discs you have loops on the botton not on top (top tension lost bottom tension higher in relation). Well thats the only explanation I have. Please post a pictures of your tension unit. The angle of the thread really matters - no joke. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members thunter9 Posted January 28, 2016 Members Report Posted January 28, 2016 can only be one of two things popped out from under the tension spring or the lint has built up under the tension spring so you don't get the tension you need . this needs to cleaned out now and then. and some times some thing get gummed up inside the bobbin and that needs cleaning Quote
Members thunter9 Posted January 28, 2016 Members Report Posted January 28, 2016 all I'm saying is take the bobbin spring out remove the screw check and clean the spring replace all and adj tension. do the same on the top remove the knob the spring and the plate,make sure its all clean , put it back together adj you tension ; with the presser foot down make sure the tensions seems to be the same . now with some scrap fine adj your tension and I hope that will do it. I might be wrong but that's about all there is . the timings not off .its making a stich. just no tension Quote
Moderator Wizcrafts Posted January 28, 2016 Moderator Report Posted January 28, 2016 There's a third and fourth possibility. 3: The thread is too well bonded onto the spool in some places but not others. As you sew the tension changes as the thread leaves the spool. 4: There is a starting thread stub sticking out of the bobbin that interferes with the smooth flow of thread off the bobbin. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members thunter9 Posted January 28, 2016 Members Report Posted January 28, 2016 yea could be that always check to see that your thread spool isn't locked up Quote
Members dikman Posted January 28, 2016 Author Members Report Posted January 28, 2016 I've already stripped and cleaned the tension assembly and had the bobbin out to check that area. Last night it occurred to me to that the only thing different is that I'd changed the thread I was using to a different colour. The one I grabbed was an old, part-spool that came with one of the machines and the thread is a little uneven on the spool in places. I didn't think it would make any difference, but from what Wiz said that may be the problem. Once I've re-assembled everything I'll change to a clean spool. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members TinkerTailor Posted January 28, 2016 Members Report Posted January 28, 2016 On 1/28/2016 at 9:58 PM, dikman said: I've already stripped and cleaned the tension assembly and had the bobbin out to check that area. Last night it occurred to me to that the only thing different is that I'd changed the thread I was using to a different colour. The one I grabbed was an old, part-spool that came with one of the machines and the thread is a little uneven on the spool in places. I didn't think it would make any difference, but from what Wiz said that may be the problem. Once I've re-assembled everything I'll change to a clean spool. If that does not work, throw it out the window...... Quote "If nobody shares what they know, we will eventually all know nothing." "There is no adventure in letting fear and common sense be your guide"
Members thunter9 Posted January 28, 2016 Members Report Posted January 28, 2016 Color can sometimes read it's the same size but it isn't.I'd still look for lint buildup Quote
Members thunter9 Posted January 28, 2016 Members Report Posted January 28, 2016 To get more even tension loop the thread through the eye on top of the machine before it goes under the attention spring hey just trying to help. Run the thread like you would and through the needle pull on the thread how does the tension feel. Compare it to the bobbin tension. They should be equal that's what you want Quote
Members dikman Posted January 29, 2016 Author Members Report Posted January 29, 2016 Sorry guys, I was talking about the wrong machine. This is what happens when I try and do more than one thing at a time! The used spool is on the Pfaff - that's been cutting the thread, but I've found a very small nick on the outside of the shuttle assembly which may be the problem. The spool on the Singer is a new, previously unused one and looks good, so I don't think that's the problem - but I won't rule it out just yet. I'll swap spools to prove it. The fact that it works for a while suggests the tensions are reasonably close and everything is working correctly, so why does it suddenly start causing loops? That sort of points to an outside interference, and the spool is the only thing "external" to the operation. Most puzzling. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Uwe Posted January 29, 2016 Report Posted January 29, 2016 Is this the machine that you broke two needles on yesterday? Maybe your safety clutch popped and timing slipped a little, or is still slipping as soon as the going gets tough? On my Tacsew, which was (and still is) having major timing problems, I noticed one setting where it made stitched, but the hook would occasionally catch the loop AGAIN after it had be pulled around the bobbin. If timing is off, no amount of thread tension adjustment will fix it. I'd flip the machine back and turn the stitches slowly by hand to make sure everything is happening exactly as it's supposed to on the underside. Quote Uwe (pronounced "OOH-vuh" ) Links: Videos
Members dikman Posted January 29, 2016 Author Members Report Posted January 29, 2016 Nah, that was the Pfaff, it obviously decided not to like me yesterday. I've already checked the timing, but yep, I guess it's time to start double checking everything again. It has to be something relatively simple. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members gottaknow Posted January 29, 2016 Members Report Posted January 29, 2016 Increase your latch opener gap and make sure the notch on the bottom of the throat plate is nick free. If the notch is beat up some, don't widen, just make it smooth. That is all. Regards, Eric Quote
Members DrmCa Posted January 29, 2016 Members Report Posted January 29, 2016 Not sure if it helps, but I had loops previously when trying to stitch too heavy leather. Is the OP pushing the machine's limits? Quote Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Members dikman Posted January 29, 2016 Author Members Report Posted January 29, 2016 Nope, Piece of veg, about 3-4 mm thick. Machine should handle at least 10mm. Going down later to finish off the Pfaff and then start on the Singer (again). Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members dikman Posted January 30, 2016 Author Members Report Posted January 30, 2016 FIXED IT!!! I thought I'd checked the hook timing, but I obviously confused myself and it was the 111W that I'd re-adjusted. (BIG senior's moment, that's what comes of trying to fix three machines at once!) Anyhow, the needle bar was too low and the needle guard on the shuttle was actually pushing the needle sideways (can't help wondering who had adjusted this previously). I re-adjusted it, but it still did it. I then checked the thread takeup spring and noticed it was only operating on the first couple of coils. Turns out it was a very tight fit in the hole in the machine body, so I modified a spare spring from a junked machine. Unfortunately, this wasn't the problem either. I started running some stitches, very slowly, and watched the takeup spring. I increased the speed and when the spring went slack I stopped and looked at everything. Bingo, the thread had jumped out of the tensioner!! No wonder I hadn't seen it before, because pulling on the threads had pulled it back into place each time. I pulled the tensioner apart, but couldn't see anything wrong, so I polished the inner faces of the discs anyway. The 3-hole thread guide next to it was in the same position as in the manual, but I shifted it in as close as I could to the tensioner. That was it, I ran stitches down the edge of an old belt and only missed one stitch (probably my fault). So Constabulary and hunter were right all along, but because everytime I looked it was ok I concentrated elsewhere. A nasty little problem, it's the last thing I would have thought could happen. Also, I fixed the Pfaff. Another tension issue, but this was a tricky one. Mine didn't have a tension release rod fitted (to open the tension discs when the foot is lifted) so I made one. The Pfaff has this wonderful bit of design where, as the presser foot is lifting during sewing, the slide that pushes on the release rod is also lifting. Which means that the length of that rod is absolutely critical. Mine was a fraction too long so as the foot lifted it released the tension discs and allowed slack thread in the stitch cycle! By carefully filing the rod I got it to the point where it didn't trip the discs while stitching but would still release them when the lever was lifted by hand. All in all, a pretty good day and my knowledge and understanding of these machines has increased tremendously. Mind you, if it wasn't for this forum I hate to think of the strife I'd still be in. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
