looking for a inside waist band holster pattern for a sig sp2022
I checked with JLSleather and he doesn't have one... this will be my first holster for a real gun and I would appreciate any advice
thanks
Lewis
If you have the gun, . . . use the search function here, . . . make yourself a pancake, . . . a simple two piece holster, . . . with the gun in the middle.
Add a couple of metal clips, . . . one on each end, . . . voila, . . . IWB holster that will work.
This will then give you the personal information as to what you DO like about it and what you DO NOT like about it, . . . so then you can make one that suits you, . . . your way.
If you look on my website, . . . my "Cactus" holster evolved in a similar fashion, . . . and is super comfortable, . . . even all day in the heat of the summer, . . . with an all steel 1911 commander in the saddle.
Good luck, may God bless,
Dwight
www.dwightsgunleather.com
If you have the "dummy", and no objection to sending it, I'd be willing to make your pattern and return both. Up to you...
5 leather patterns
Dwight...
thanks for your input I will try and make something like yours... don't really want to do a lot of holsters but its for a friend. Where can I get a couple clips like you use
thanks
Lewis
Dwight
thanks for the offer but I am just making 1 for a friend... so no dummy gun
I appreciate your input
Lew
Biglew, . . . I don't use clips, . . . I use a strap that is basically just a 3/4 inch wide piece of leather, . . . and it snaps onto the tip of the holster sides.
May God bless,
Dwight
Edited by Dwight
Thank you so much
May God bless,
Dwight
Biglew, . . . if you have not already seen this, . . . take a look, . . . this pancake is a bit different from the ones I make, . . . but look to be quite sturdy and useful.
This is also an easy to make holster.
http://leatherworker.net/forum/index.php?showtopic=68882&hl=
May God bless,
Dwight
