This a pattern I made a couple of years ago for a Ruger LCP.
 One of our members asked me to share it so I thought I would share it with everyone.
In use, I carry on my right side with the holster horizontal and the butt of the weapon facing up. This is a very comfortable mode of carry and is very concealable.
It isnt probably the best design but it works for me.
LCP HOLSTER.pdf
LCP HOLSTER.pdf
Thanks very much!
Chris
Thanks
Nice pattern, thank for putting it on here! Thanks much!
Thank you very much.
rick
Am I the only one who doesn't "get" the belt loop thing, and the dotted vertical line right in that area?
The Dashed line is the first sewing line. What I did was sew the belt loop on at the top then got the loop material wet with a spnge and formed it across a piece of 9-10 oz leather...clamped till dry. Then I glue lightly along the bottom edge of the loop and wait for it to set. Then I sew in place. The loop is 2-1/2 square. I showed it in place with very light dots because I was merely pointing out where I located it. You are more than welcome to position it as you please.
Hope that helps.
Eric
  • 3 months later...
That does help. And thank you for posting this
  • 2 years later...
A couple of pictures of the holster I made from the pattern at the beginning of this thread.
