Moderator Wizcrafts Posted December 1, 2022 Moderator Report Posted December 1, 2022 On 12/1/2022 at 5:16 AM, Leebroox said: I will probably switch to #21 or #19 and 138 or 92 thread, if I cannot get the 207 to take like I want Expand I use a #19 needle with v92 and a #22 or #23 with v138 bonded thread. If you use a needle that is too small it makes tighter holes and the take-up lever has to work harder to pull the knots up. It also tends to lift the leather as the threaded, knotted needle ascends. This causes missed stitches and ratted top thread. Here's a needle and thread chart that I consult. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members shoepatcher Posted December 1, 2022 Members Report Posted December 1, 2022 Smallest needle you can use #138 on is #22. I use #23 titanium coated. Less deflection and the coating makes the needle slide easier thru leather. glenn Quote
