Members glockanator Posted June 7, 2016 Members Report Posted June 7, 2016 So I have three different color threads for my boss. White, red, and dark brown. When I use the red and brown on my test pieces they run perfect. Start on my project and the top thread starts shredding and a huge know on the bobbin side. If I change to my white and make ko adjustments it runs perfect. Any suggestions on why this might be happening? Quote
Contributing Member TwinOaks Posted June 7, 2016 Contributing Member Report Posted June 7, 2016 .Even if the test and project pieces are the same thickness, are they from the same side? Does the project have a glued seam that you're sewing through? Is the project piece a firmer/softer hand? Are the threads the same brand? Since it sews fine on a test piece, I'll presume the threads are the same twist. It sounds like maybe a combination of the stiffness of the thread and the needle's interaction with the project leather. I have white, black, brown and natural (good heavens...will the spool EVER run out?) and the 'natural' color is a MUCH stiffer thread; presumably because it has a different type of, or maybe just more bonding. When the needle starts its upward movement, the loop forms at the scarf and the hook picks it up...it sounds like the loop isn't forming correctly and maybe the hook is catching it right on the thread, resulting in tearing/cutting the thread. If your white thread is stiffer, it may be forming the loop more easily, allowing the hook to pass like it should. Double check the needle position, try a slight rotation either direction to see if it helps. Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
Members Colt W Knight Posted June 7, 2016 Members Report Posted June 7, 2016 Colored thread is notorious for being stiff and can be hard to sew with. I have a spool of black I can't do anything with. Quote
Moderator Wizcrafts Posted June 7, 2016 Moderator Report Posted June 7, 2016 2 hours ago, Colt W Knight said: Colored thread is notorious for being stiff and can be hard to sew with. I have a spool of black I can't do anything with. Black bonded thread is double dyed making it sometimes act like a coil spring. I had to use Weaver #207 thread to sew a couple dozen rifle slings last Saturday and it kept twisting around posts and guides and even itself. This caused numerous skipped stitches. The Weaver Chestnut brown thread did not have quite as much springiiness. If I find a source of non-coily black bonded thread, I buy more than one spool. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members gottaknow Posted June 7, 2016 Members Report Posted June 7, 2016 We use Coats bonded nylon. It seems about the best for not coiling too bad. We even use the black in T135 for the gimp thread in our keyhole button holes, (which has to be pretty much coil free). Regards, Eric Quote
Members Darren Brosowski Posted June 11, 2016 Members Report Posted June 11, 2016 Had a similar problem on a Boss that a mate had. The thread was dark brown but it was absolute garbage. The two biggest problems with sewing machines are thread and needles Quote
