Members tagger609 Posted July 1, 2016 Author Members Report Posted July 1, 2016 I will try to loose the pressure of the presser foot. What type of needle do you recommend if not the LR Quote
Members Ken Nelson Posted July 1, 2016 Members Report Posted July 1, 2016 I use 794S needles on my Cobra Class 4. If you don't have a really good operators manual with this machine, I would suggest you go to the Artisan site and pull down the manual for the Toro series machines. It is really good and is way more indepth than most of the 441 manuals. I used to trade on used sewing machines a little. I only bought one from individuals that sewed when it come into the shop. None of them took any parts, just a lot of adjusting and I got lucky there. I have seen some that were so worn out it cost more for parts than the machine was worth. Learning how to adjust these machines is part of learning how to sew. Do not let it scare you. It is not rocket science and there is a lot of help available. A really good manual or mechanics video is worth a lot. HTH's Ken Quote
Members tagger609 Posted July 3, 2016 Author Members Report Posted July 3, 2016 Ok so i checked for burrs, None to be found. Redid the tension on top. Tried different needles , needle sizes, point shapes, and thread thicknesses top and bottom ( combinations of 277 / 207) bonded polyester thread. No luck. You can see a little fray on the top stitch and a ton on the bottom stitch. If i go in reverse it is a nightmare with the fraying. Quote
Moderator Wizcrafts Posted July 3, 2016 Moderator Report Posted July 3, 2016 Did you buy the Ferdco from an individual or a sewing machine dealer? If a dealer, contact them about returning the head for repairs. If the seller can't help you, one of our member dealers probably can. Check the banners on top of our forums for links to our supporting dealers' websites. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Northmount Posted July 3, 2016 Report Posted July 3, 2016 If you use leather point needles, don't back tack. Leave your thread tails long and do your back stitching by hand, doing a saddle stitch. Tom Quote
Members tagger609 Posted July 3, 2016 Author Members Report Posted July 3, 2016 Im not worried as much about the backstitch as i am the small fraying coming up through the top stitch as pictured. The back stitch was mostly solved by the washer trick ive read about. Far right stitch line is of the top stitch and the small frayed pieces. Quote
Members tagger609 Posted July 4, 2016 Author Members Report Posted July 4, 2016 Wiz, Dealer said to ask you guys ! Quote
MADMAX22 Posted July 4, 2016 Report Posted July 4, 2016 Haha thats not good. I mean Wiz and the guys are great but that dealer should be fixing the machine he/she sold ya. Quote
Moderator Wizcrafts Posted July 5, 2016 Moderator Report Posted July 5, 2016 11 hours ago, tagger609 said: Wiz, Dealer said to ask you guys ! No shit? Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Trox Posted July 5, 2016 Report Posted July 5, 2016 The first thing you do with stitch errors are to change to a new needle, bad needles cause 90 % of all stitch errors. No matter how old that needle is and do not look for burrs on it, just change it for a new one. Then look for burrs on your hook tip, check the inside foot and hole in the needle plate for the same. Use your finger and a magnifiers, look for anything that might cause that fraying. When it comes to the adjustment, it's not your job to adjust the machine. Have it delivered back for repairs or let them come and adjust it in your place. You have a warranty, if you start doing repairs yourself that might not be valid anymore. You will learn how to adjust the machine soon enough, a brand new machine should be sewing fine when you receive it. Tor Quote Tor Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
