Members Red Cent Posted July 11, 2016 Members Report Posted July 11, 2016 I use the glycerin bar on dry firm edges only. And I use it after sanding and burnishing. If your edges have the look of a sponge, you got it too wet or it is spongy leather. The bar won't help. After beveling and sanding, a light wipe with a wet rag should set you up for burnishing and a glassy smooth edge. Nothing else is needed. After I dye the edges I burnish with a well used dowel rod that will smooth the edges surprisingly well. If the dye causes some roughness, I will get out the glycerin bar. I never use saddle soap. Quote https://www.facebook.com/redcentcustomleather?ref=bookmarks http://www.redcentcustomleather.com/
