Members glockanator Posted July 24, 2016 Members Report Posted July 24, 2016 I did this holster for Deputy_hookem on instagram. The image is of his hip hop CD cover. Quote
Members alfredleatherworks Posted July 25, 2016 Members Report Posted July 25, 2016 That is pretty cool! I haven't the foggiest idea how you did that, but it is really slick! Quote
Members glockanator Posted July 27, 2016 Author Members Report Posted July 27, 2016 On 7/24/2016 at 8:18 PM, alfredleatherworks said: That is pretty cool! I haven't the foggiest idea how you did that, but it is really slick! This is how I did it. Quote
Members alfredleatherworks Posted July 28, 2016 Members Report Posted July 28, 2016 On 7/26/2016 at 11:35 PM, glockanator said: This is how I did it. OK, that has to be one of the coolest things I've watched in a while. Thanks for sharing that! I just might have to try this soon! Quote
Members Dwight Posted July 30, 2016 Members Report Posted July 30, 2016 Hey, Glockanator, . . . good job my friend. I had seen that video, probably over a year or so ago, had forgotten how he did that. Thanks for the reminder, . . . I just may do something with that, . . . got a couple things in mind, . . . May God bless, Dwight Quote
Members keplerts Posted July 31, 2016 Members Report Posted July 31, 2016 Was the leather WET or DRY when you transferred it? Looks like it held up during the wet forming of the pistol. Quote
Members glockanator Posted August 1, 2016 Author Members Report Posted August 1, 2016 On 7/31/2016 at 2:20 AM, keplerts said: Was the leather WET or DRY when you transferred it? Looks like it held up during the wet forming of the pistol. It was dry. The one thing I will say was this was my second attempt. The first one I did not leave to dry long enough so when I put on the resolene it faded bad and made the image all muddy. On this one I let it sit for about 3 days (may have been over kill) and then buffed it before I put the finish on. It still faded but not like the other one did. Quote
Contributing Member Ferg Posted August 2, 2016 Contributing Member Report Posted August 2, 2016 Just as a side note: You can use a good laser printer for image transfer. Print on very good quality white copier paper, remember to reverse the image. Use a heat press, home clothes iron doesn't work well. You will need to test your press time on some scrap of leather you intend to use. After the print is transferred you need to "Fix" the image in an oven. Small $100 ovens work great. Apply temperature of 250 to 275 for about 2 to three minutes. The oven makes the image permanent. Ferg Quote
Members glockanator Posted August 2, 2016 Author Members Report Posted August 2, 2016 5 hours ago, Ferg said: Just as a side note: You can use a good laser printer for image transfer. Print on very good quality white copier paper, remember to reverse the image. Use a heat press, home clothes iron doesn't work well. You will need to test your press time on some scrap of leather you intend to use. After the print is transferred you need to "Fix" the image in an oven. Small $100 ovens work great. Apply temperature of 250 to 275 for about 2 to three minutes. The oven makes the image permanent. Ferg Thanks for bringing this point up as I forgot to mention it. As this was my first attempt at anything like this. I did use a iron to hest the image after I let it dry for a couple of days. I think an oven would work better though. Quote
Members Lizardo Posted October 5, 2016 Members Report Posted October 5, 2016 I like it! The slight fade adds character to it, not in your face, just a bit more subtle. Quote
