Members thekid77 Posted August 6, 2016 Author Members Report Posted August 6, 2016 2 minutes ago, RockyAussie said: Yep that should work fine but don't let the blade get near the glue layer of course. Note: make sure that the to be wasted piece is very even in thickness or your thin piece will vary similarly.Have you tried the thicker piece without glueing? I do that sometimes but with a longer piece due to the top going in faster than the bottom piece. I thought about doing that too....just wasn't sure if the two pieces needed securing w the glue or not Quote
RockyAussie Posted August 6, 2016 Report Posted August 6, 2016 Let us know how you go. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Contributing Member Ferg Posted August 6, 2016 Contributing Member Report Posted August 6, 2016 Glue with gel contact cement not barge or similar. Coat with a thin layer on each piece and let lay for at least an hour before you place the two together. Roll to make them adhere fully. I agree you may have a problem if the thick piece isn't almost exactly the same thickness throughout. Ferg Quote
