Members CraftyNick Posted September 9, 2016 Members Report Posted September 9, 2016 (edited) I am not asking any questions in this post about whether this would work, because I already tried it. Nor am I recommending this unconventional idea to anyone because it didn't work all that well. Just sharing for the sake of interest or discussion, or in case anyone else out there is wondering about the idea. To begin, I carved a set of tracks that I had drawn deeply into a piece of leather (one front and one back bear paw - no, I didn't bother to make a right and left - they're both left ). Then, after soaking the leather in neatsfoot oil, I filled the impressions with JB weld. After removing the JB weld nuggets from the leather cast I had semi functional stamps. The front paw was too thin so it cracked during use, the back paw just lost it's fifth toe, but they stayed together enough to get the project done. Best part of it all was that I got the belt decorated just as I had imagined. That was the whole point. (Yeah, I could have just bought a bear paw track from etsy, but I had no time to order one because I had to get the belt done for somebody's birthday and I never plan ahead very far). Edited September 9, 2016 by CraftyNick Quote
bikermutt07 Posted September 10, 2016 Report Posted September 10, 2016 I like the rustic look of it. I love hearing about obscure tricks that kind of work. Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
Members CraftyNick Posted September 11, 2016 Author Members Report Posted September 11, 2016 Thanks for the comments Quote
Members Halitech Posted September 11, 2016 Members Report Posted September 11, 2016 might not be the "right" way of doing things but if it's going to be a 1 time use stamp, makes more sense then spending 50.00 on a custom stamp. Maybe if you had made it thicker and added a washer in the middle, it may have lasted longer, especially if you used a press instead of a hammer Quote Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
Members TinkerTailor Posted September 11, 2016 Members Report Posted September 11, 2016 6 minutes ago, Halitech said: might not be the "right" way of doing things but if it's going to be a 1 time use stamp, makes more sense then spending 50.00 on a custom stamp. Maybe if you had made it thicker and added a washer in the middle, it may have lasted longer, especially if you used a press instead of a hammer I have used metal window screen as reinforcement in jb weld projects (not stamps)in the past, kinda like rebar in concrete. Stops cracks. I wonder if you couldnt embed some into a stamp? I bet if the jb was at at least 10mm thick and it was backed by some metal, with a screen embedded it would last longer. Imma gunna try it. Quote "If nobody shares what they know, we will eventually all know nothing." "There is no adventure in letting fear and common sense be your guide"
Members Halitech Posted September 11, 2016 Members Report Posted September 11, 2016 the metal screen would probably work better in the middle then the washer and yeah, get it at least 10mm (3/8" for our SAE members) and add the washer to the top and I bet it would last longer. Think I'll give it a shot on Monday when the stores are open that I can get to as well Quote Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
Members CraftyNick Posted September 11, 2016 Author Members Report Posted September 11, 2016 (edited) There is a front/back bear paw stamp on etsy but yeah, they are $22 a piece. I bet it could be done a lot better than my first, sort of, crude attempt. Using a press might be a good idea, if you have one. Adding some backing to the stamps would be very helpful. I used a piece of leather for backing, but there are probably better materials. It was hard to hit the stamps without a post attached, so I put a regular stamp to the back of the homemade stamps and pounded the stamp indirectly through the other stamp post, which is what broke it, so a rigid backing on the homemade stamp is advisable if you are going to do that. Edited September 11, 2016 by CraftyNick Quote
Members LumpenDoodle2 Posted September 11, 2016 Members Report Posted September 11, 2016 What a perfect idea for a one off design stamp. Looking forward to a report on youe 'upgrade'. Quote “Equality? Political correctness gone mad, I tell you, gone mad!!!! Next they'll be wanting the vote!!!!! “. Anger and intolerance are the enemy of correct understanding
Members R SFraser Sr Posted September 12, 2016 Members Report Posted September 12, 2016 A bit off topic, Nick, but can you tell me where you got that style buckle? thanks bob Quote
Members CraftyNick Posted September 12, 2016 Author Members Report Posted September 12, 2016 This is the 1 1/2 inch roller buckle with the center bar that Tandy sells. It's not as quality as I would like it to be, but there are not many options for this style of buckle apart from this one that I have found. Quote
