Members Windrider30 Posted September 20, 2016 Members Report Posted September 20, 2016 Ok i have an idea i want to try with a leather corset. I need two rows of holes aligned as near perfect as possible. So how do i go about doing this, i need two vertical rows how do i go about keeping the spacing even as when i try just eyeballing this the distance between holes is a little off and for the lace work i have in mind the spacing needs to be as close to perfect as i can get. Quote
Members TonyRV2 Posted September 20, 2016 Members Report Posted September 20, 2016 I'm not sure I'm following what the problem is so I'll point out the obvious...why not carefully measure and mark where you want the holes to be as opposed to 'eyeballing'? Quote Tony VRifle River Leather Ogemaw Knifeworks There are two individuals inside every artisan...the poet and the craftsman. One is born a poet. One becomes a craftsman.
Members Windrider30 Posted September 20, 2016 Author Members Report Posted September 20, 2016 basicly I need two lines like this . . . . . . The problem with measuring is that I am not sure where to measure from after the first hole so that it lines up. If I should measure from the bottom of the hole, top of the hole down, because even going from the center I still get it a little off center even after marking where I want the holes in the first place. 7 hours ago, TonyRV2 said: I'm not sure I'm following what the problem is so I'll point out the obvious...why not carefully measure and mark where you want the holes to be as opposed to 'eyeballing'? Quote
Members Halitech Posted September 20, 2016 Members Report Posted September 20, 2016 (edited) how about using a wing divider? trace your line out where you need it to go then "walk" the wing divider along the lines. That way, you have a small spot and you aren't trying to figure out where to measure from Edited September 20, 2016 by Halitech Quote Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
Northmount Posted September 20, 2016 Report Posted September 20, 2016 (edited) Don't measure from hole to hole, as any small errors will keep increasing and throwing your two rows out of sync. Keep the ruler (use a ruler or tape) in place, mark off each hole without moving the ruler down each time. So if you were making the holes 1/2" apart, you mark at 0, 1/2", 1", 1.5", 2", etc. If you use a scratch awl or pencil/pen, just make small marks in a straight line. When punching, press the punch centered over the mark, just hard enough to leave a slight impression. Check to see if it is centered, correct the location if not, then punch the hole using the mark plus the punch impression as a guide. You could make a punching guide or template out of a strip of wood or plexiglass or similar plastic material if you will be making several articles the same. Will help speed up production. You could also use painters green tape to place your marks, and punch through it, then remove the tape after. Then you won't be marking the leather itself. Tom Edit: Or modify this as Halitech suggests above. We posted at the same time! Edited September 20, 2016 by northmount Quote
Members TinkerTailor Posted September 20, 2016 Members Report Posted September 20, 2016 1 hour ago, northmount said: Don't measure from hole to hole, as any small errors will keep increasing and throwing your two rows out of sync. Keep the ruler (use a ruler or tape) in place, mark off each hole without moving the ruler down each time. So if you were making the holes 1/2" apart, you mark at 0, 1/2", 1", 1.5", 2", etc. If you use a scratch awl or pencil/pen, just make small marks in a straight line. When punching, press the punch centered over the mark, just hard enough to leave a slight impression. Check to see if it is centered, correct the location if not, then punch the hole using the mark plus the punch impression as a guide. You could make a punching guide or template out of a strip of wood or plexiglass or similar plastic material if you will be making several articles the same. Will help speed up production. You could also use painters green tape to place your marks, and punch through it, then remove the tape after. Then you won't be marking the leather itself. Tom Edit: Or modify this as Halitech suggests above. We posted at the same time! Careful with the painters tape, I have had it stick and leave residue on some distressed leathers and more frequently when i use it on the backside. Not sure why. I just decided to stop using green tape on leather to prevent it. I do dust the backside of my patterns with super77 sometimes, then rub it a bit with my hands to reduce tack. It works great to give patterns that little bit of "stay right there while i trace/punch" Quote "If nobody shares what they know, we will eventually all know nothing." "There is no adventure in letting fear and common sense be your guide"
Members Windrider30 Posted September 22, 2016 Author Members Report Posted September 22, 2016 Great ideas thanks all!!!! Quote
Members ENC Posted September 22, 2016 Members Report Posted September 22, 2016 What several of my friends have missed when doing hole layouts is there is 1 less division than there are holes. 11 holes 1 in apart cover 10 in because you have a hole at 0. Also its much easier to use metric measurements, it's much easier to mark out 5.76 mm than 2.4 inches, after you do the spacing division and end up with strange decimals. I use a XL spread sheet to do the math for me and come up with a measurement for each hole then place the ruler , clamp it and, mark each measurement distance from the 0, avoiding iteration error like you get from walking dividers. Ray Quote
Members TheCyberwolfe Posted September 22, 2016 Members Report Posted September 22, 2016 Then there's the lazy man's solution - the Point 2 Point divider: http://www.garrettwade.com/point-2-point.html Pick the number of holes you want, stretch it out until it covers the distance you want, and voila! No crazy fractions to worry about. Quote -- I don't suffer from insanity, I enjoy every minute! www.rogueleather.com
