Prevent leather dyed with Tandy waterstain from lightening in areas where folded??
Hey everybody
I noticed that when I dye leather with the tandy waterstain, after it has dried and I buff it, it really lightens up on areas where it's bent.....any suggestions on how to prevent this from happening? Thank you in advance for any advice you can share!!
  • 2 weeks later...
That effect is almost inherent in any absorbed dye, unless it is applied so heavily that the effect is not noticeable.  In bending it, you stretch a certain amount of color over a larger area, so the amount of color per inch is lowered.
Solution?  Bend first.
Hi John! Thank you so much for sharing your knowledge :) Much appreciated!!
Bending first works for me:
Keep on Chooglin'
Check out my YouTube Channel, comment and subscribe for updates
https://www.youtube.com/channel/UCOM3hbruUKHov9kquIxXKlA
It's called "pull up".  Some like it, some don't.  I've seen finished leather designed to do just that.  I have better luck with the Pro Oil line from Feibings.  Seems to get deeper in the leather.
