No cure - learn to live with it! :lol:
  • Replies 23
  • Created
  • Last Reply
Top Posters In This Topic
Thanks for the prices, Darren - I think :(. Because this is only a hobby for me (and I sell very little, only to fellow shooting club members who ask me to make something for them) I can't even consider one at those prices- unfortunately. It just means I have to handstitch the really thick stuff.
Whiz, if you lived closer (;)) we could possibly do a deal on my Singer postbed machine.
Ok, a few photos of my latest acquisition.
 It appears to be in pretty good condition, just needs a bit of fluff cleaned out and oiling. It's a large bobbin (yay) and I got 5 spares with it, a bunch of needles (probably cloth) and some oddments of thread (#69). I also bought some nice imported Irish Tweed from her as I'm thinking it might make a couple of nice rifle bags.
So, a question for all you knowledgeable types - how do I figure out what model it is? I can't find any model number, the only thing on it is a serial number - TH 9908501.
After looking at lots of google images of Seikos, I could only find two of an STH-8BLD, but both had the black stitch adjustment dial like mine, whereas the 8BLD-3 all have a light coloured dial.
So I figure mine's an 8BLD. Next question is what's the difference between the D and the D-3? I haven't been able to find a manual for the 8BLD yet.
maybe a difference in foot lift or hook size? Isn´t there a list that explains the letters and numbers? I think on the old Seiko website they had an explanation...
Sold in the USA by Consew, this was sold as a model 206RB-3, the -4s were white.
This model -3 was one of the very best Consew 206RB models in the series.
Foot lift at the knee lifter is 9/16", same for all 206RB-3, 4 and 5s.  All Consew 206RB subclasses and Seiko STH-8BL subclasses use the same hook, bobbin, and bobbin case.
Edited by Gregg From Keystone Sewing
Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Gregg, are you saying that mine's probably a 3? I've downloaded the manual (from your site :)) for the 3 and everything looks the same.
The bottom oil tank (that feeds the hook) was empty and all the oil wicks/felt pads were dry so I oiled everything that moved (!) and left it overnight. The woman said that there was a bit of a problem with lower thread tension, but I noticed when dismantling it that a lever/arm next to the hook was poking out at an angle and didn't seem to be doing anything. This, as I found out, is the latch opener, and definitely needs adjustment!! I also suspect that the two feet need re-adjusting, all minor things. Hopefully today I can spend time going over the adjustments.
I'm also considering fitting a larger pulley to the head, in place of the handwheel. I did this to my Pfaff and it makes a huge difference to the low speed control and torque, and is much easier than messing around with speed reducers.
Looking good so far. Fixed the latch opener, needle bar needed re-adjusting (the needle that was fitted was shorter than the specified needle), both feet needed re-adjusting, the thread friction discs are grooved (not surprising) so I reversed them front-to-back which moved the grooves away from the thread path, and the "biggest" problem, the screw that holds the needle in had one side of the screwdriver slot missing! I couldn't find anything among my supply of screws that matched the thread size (I've got no idea what it is) so as a last resort I silver soldered the busted screw to the head of a larger screw. Not pretty, but it works. It came with welting feet fitted, but fortunately I seem to be accumulating a collection of assorted spare feet so fitted a standard set.
Loaded up some #69 thread and handcranked on some scrap leather with no problems. Next thing was to load up some #138 thread, again it didn't miss a beat, basically whatever I could fit under the feet it sewed.
Next thing is to hook it up to a motor and see if it will sew a long run.
Hooked it up to a motor and tried a run down an old belt with #138 thread - beautiful, didn't miss a beat. Two pieces of scrap veg, just over 1/4" thick, and it treated it like a very thin piece, perfect stitches. I've got no doubt this thing will sew whatever I can fit under the feet. And I reckon it might handle #207, just a pity I haven't got any to try.
Me happy :), me like :):).
Now I think I know why folks like their Seikos/Consews so much.
Almost done, just have to sort out the knee lifter. The tabletop came with it so I re-used it but fitted it to stronger legs (the kneelifter positioning is different to the Singers so it was easier to use the original table rather than drop it onto a Singer table).The motor has a 1 3/4" pulley so fitting an 8" on the head unit gives me a 1:4.4 reduction, and coupled with the servo I can crawl it nicely with lots of torque.
I just need to replace the belt with a smaller cross-section one, as while this one works I think it's a bit too stiff. (Since I started this sewing machine thing I've accumulated quite a selection of belts but I never seem to have the size I need :blink:).
Got yourself a great bargain there Richard, same machine as mine, and I thought I did well for $500 ! mine wasn't stitching at all when I bought it, but found some silly person had put the needle in back to front, corrected and sews like a dream.
You wont regret it these are a fantastic machine.
