Reegesc Posted February 8, 2017 Report Posted February 8, 2017 I have put off asking this question for months because it sounds so stupid simple, but I'll be damned if I can figure it out. Hoping one of you Gurus can set me straight on this. Here's the deceptively simple question: How do you find true top center on a dog collar, for tooling names or anything that requires accurate center placement? Here's the problem that I keep running into. Dog collars are not worn as belts are and therefore Saint Al's belt-centering formula does not work (Center Buckle + 1/2 Waist Size) or when it does it's just dumb luck. A dog collar buckle isn't naturally centered at true center bottom like belt buckles are centered in the front of the waist. The true bottom of a collar is the center of gravity of the buckle assembly plus the weight of the leather on either side, in particular the Billet hanging off to one side, IT seems to me that to find true top center as defined by a worn collar, the formula has to account for the weight and the distribution of that weight. And I just get lost at that point. Is there an easy way to figure this out without having to get out the graph paper and the gram scale? I swear I screw it up every time just trying to eyeball it and I'm picky as hell and it drives me up a wall. The thing is there's very little real estate on a dog collar to begin with and a half an inch either way stands out like a sore thumb. Help me Obi Wan... Quote
Members Mattsbagger Posted February 8, 2017 Members Report Posted February 8, 2017 Don't Gonzales has a short video on doing it on belt. I have no idea if that's the way Altenburg Stohlman does it. That's all I got. Sorry. Matt. Quote
Members Big Sioux Saddlery Posted February 8, 2017 Members Report Posted February 8, 2017 This is a good question, and I have struggled with it myself. On the last one I did, I assembled the collar (buckle and dee ring) before I did any stamping, and then buckled it into the hole that the measurement indicated it would be. Then I let the collar hang loosely from my hand and shook it around, so that gravity would hopefully center it like it would when on the dog. Then I went from there. As it turned out, the owner tightened it up one hole from where I figured it would be adjusted (owner had also done the measuring), so it wasn't quite right anyway. But owner and dog were delighted regardless. And you are so very right, very little room to work with on a dog collar, and the smaller the dog, the worse it is! I'd like to know if there is a formula as well, but in any case, the measurement has to be spot on or the formula will be off. Quote
Reegesc Posted February 8, 2017 Author Report Posted February 8, 2017 I wonder if water buoyancy would reveal true bottom center? What I'm thinking is if you had a clear container and filled it with water, then lower the collar into the water and look at from the side, the lowest point should be true bottom center, right? Then just straight up from there is true top center......theoritically. Ya know, it's something you could do before dyeing and finishing.. I dunno....just guessing at it. Surely somebody has cracked this nut before. Quote
Members TomG Posted February 8, 2017 Members Report Posted February 8, 2017 Well, although I also like to be as accurate as possible, it honestly does not really matter. I do hundreds of collars. I use the exact method as shown in the image above and It comes out close enough. I have never, ever had a customer say "great collar, but the name is 1/2" off center". Different buckles, different sizes, customer mismeasurements that cause different hole used (as pointed out by Big Sioux), and other factors beyond your control make, it almost impossible to be super accurate every time. But, if you insist on making it "dead nuts on", using Big Sioux's preassembly method is about the only practical method. It takes all factors in to account automatically... assuming the same hole is used. Good luck Quote Tom Gregory Legacy Leathercraft www.legacyleathercraft.com www.etsy.com/shop/legacyleathercraft
Members Dwight Posted February 8, 2017 Members Report Posted February 8, 2017 Make yourself a long triangular shaped piece of wood with a flat on the top of it about 1/16 of an inch wide. Get a flat piece of aluminum, . . . sheet metal, . . . plastic, . . . whatever, . . . about 2 inches wide, . . . and maybe 18 inches long. Lay the collar down on the 2 inch wide piece, . . . center it so it is in the middle of the 2 inch wide piece, . . . then lay that on the triangle. Move it back and forth until you find where it balances, . . . that is the "weight" center of the dog collar. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Reegesc Posted February 8, 2017 Author Report Posted February 8, 2017 TomG, you of course are right. You're running a business and I'm running an ego. Nevertheless this should have a simple answer. And if not, then a hard answer. I'll take either one. :-) Thanks for the perspective though. Quote
Reegesc Posted February 8, 2017 Author Report Posted February 8, 2017 Hey Dwight, yeah I can see that working. Going to give that a try. Thanks a bunch man, Quote
Members TomG Posted February 8, 2017 Members Report Posted February 8, 2017 1 hour ago, cseeger said: TomG, you of course are right. You're running a business and I'm running an ego. Nevertheless this should have a simple answer. And if not, then a hard answer. I'll take either one. :-) Haha.. I got the ego too , but I've just learned over time what's worth the extra effort. I think that you are going to find that the "buckle it up and let it hang" method is going to be about the best "practical" method with the best accuracy. I like Dwights idea, but not sure I'd have the patience to make all of that balance out. Especially 5 or 10 times a day. Quote Tom Gregory Legacy Leathercraft www.legacyleathercraft.com www.etsy.com/shop/legacyleathercraft
Members Dwight Posted February 8, 2017 Members Report Posted February 8, 2017 27 minutes ago, TomG said: Haha.. I got the ego too , but I've just learned over time what's worth the extra effort. I think that you are going to find that the "buckle it up and let it hang" method is going to be about the best "practical" method with the best accuracy. I like Dwights idea, but not sure I'd have the patience to make all of that balance out. Especially 5 or 10 times a day. Mark the ends of the aluminum 2 inch piece, . . . mark them in from the ends in 1 inch increments, . . . flop the collar down on it, . . . center it, . . . put it on the triangle, . . . should be done in all of about 15 seconds. I don't think I could buckle it, . . . find it's "point" and unbuckle it any quicker than that, . . . especially with 72 year old fingers that don't like to mind all the time. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
