Members bakdrft Posted March 1, 2017 Members Report Posted March 1, 2017 (edited) Untitled by bakdrft, Untitled by bakdrft, on Flickr Having problems with the black. It was put down first (3 coats) then satin sheen then burgundy then the antique,, Why would black fade? Edited March 1, 2017 by bakdrft Quote
Members Mattsbagger Posted March 1, 2017 Members Report Posted March 1, 2017 More info needed. What brand and style. ie: spirit based or water based. Fiebings or eco flow. Quote
Members bakdrft Posted March 1, 2017 Author Members Report Posted March 1, 2017 Untitled by bakdrft, 4-5 Veggie Tan Quote
Members Mattsbagger Posted March 1, 2017 Members Report Posted March 1, 2017 I've never used eco flo dye. Never needed more than one coat of Fiebing's pro oil. Have to buff well to get any pigment off surface. For multiple colors on same piece might wanna look into cova colors. Acrylic paint by eco flo. Quote
Members Ed in Tx Posted March 1, 2017 Members Report Posted March 1, 2017 Using something like Fiebings Deglazer prior to the dye might help. The Deglazer will remove the glaze that occurs during the finishing processes at the tannery. Quote
Members bakdrft Posted March 2, 2017 Author Members Report Posted March 2, 2017 I have used the black as a solid single color on a knife sheath 2 coats and then the sheen. Turned out well. Not sure which messed it up, maybe the combo of satin sheen and eco flo Hi Lite together... Thanks for your replies John Quote
Members bakdrft Posted March 3, 2017 Author Members Report Posted March 3, 2017 OK, so I purchase Fiebings Pro Dye,,,,, No problems. Eco Flo in the garbage Quote
Members Mattsbagger Posted March 3, 2017 Members Report Posted March 3, 2017 Make sure you stay away from the US MC from Fiebings apparently you will have to spend days buffing the excess off. Love the Pro dye never needed more than one coat. Good luck. Quote
Members Grihm Posted March 11, 2017 Members Report Posted March 11, 2017 Question. Do you remember if the Eco Flow felt " stringy " or " slimy " when you applied it to the sponge? Quote
NVLeatherWorx Posted March 12, 2017 Report Posted March 12, 2017 13 hours ago, Grihm said: Question. Do you remember if the Eco Flow felt " stringy " or " slimy " when you applied it to the sponge? You should be applying it with a dauber, sponges don't give you the right application surface to get a good penetration. This whole thing of using sponges for applying everything and the constant failure of researching a question before posting it (because these issues are rehashed over and over again on just about a daily basis in one place or another here) are the biggest reasons why these issues continue to plague everyone. If you want a solid application of product then use the proper application tool: Dye/liquid stain = dauber Top Coat/Finish and Oil = synthetic/sheepskin pad Antique Paste = sheepskin pad Fine/Detail coloring = proper sized paint brush Edge finish = modified dauber (should know how to do this) Products that get proper results: Spirit based products give best, and most consistent, results without question. These products have been around much longer than any water-based products and have a proven track record the world over. Water-based products are just somebody's "feel good about themselves" idea of trying to make people think that they can do their part to "save the world", well, it doesn't need to be saved because there is nothing wrong with it and these products DO NOT provide a quality result (as is repeatedly addressed within this community). If you are looking to make quality finished goods then you need to use quality raw materials and supplies to do so, trying to create quality from garbage has already been tried and has failed repeatedly, it is what we call "mass produced" and is found everywhere that our client base THINKS is out to help them better their daily lives by bringing them "value" when all they are doing is bringing them stuff that fails quickly and needs frequent replacement. A professional should be striving to bring change to that thinking by providing a product that is intended to outlast that crap that is typically purchased. Quote Richard Hardie R. P. Hardie Leather Co. R. P. Hardie Leather Co. - OnlineR. P. Hardie Leather Co on Facebook
Members Grihm Posted March 12, 2017 Members Report Posted March 12, 2017 (edited) 9 hours ago, NVLeatherWorx said: You should be applying it with a dauber, sponges don't give you the right application surface to get a good penetration. This whole thing of using sponges for applying everything and the constant failure of researching a question before posting it (because these issues are rehashed over and over again on just about a daily basis in one place or another here) are the biggest reasons why these issues continue to plague everyone. If you want a solid application of product then use the proper application tool: Dye/liquid stain = dauber Top Coat/Finish and Oil = synthetic/sheepskin pad Antique Paste = sheepskin pad Fine/Detail coloring = proper sized paint brush Edge finish = modified dauber (should know how to do this) Products that get proper results: Spirit based products give best, and most consistent, results without question. These products have been around much longer than any water-based products and have a proven track record the world over. Water-based products are just somebody's "feel good about themselves" idea of trying to make people think that they can do their part to "save the world", well, it doesn't need to be saved because there is nothing wrong with it and these products DO NOT provide a quality result (as is repeatedly addressed within this community). If you are looking to make quality finished goods then you need to use quality raw materials and supplies to do so, trying to create quality from garbage has already been tried and has failed repeatedly, it is what we call "mass produced" and is found everywhere that our client base THINKS is out to help them better their daily lives by bringing them "value" when all they are doing is bringing them stuff that fails quickly and needs frequent replacement. A professional should be striving to bring change to that thinking by providing a product that is intended to outlast that crap that is typically purchased. The question was more in relation to a problem i have had with bad quality antique. We bought a black antique, but when pouring it out from the bottle, the consistency was slimy and a bit rubberbandy, and not fluid as it supposed to be. The result of the color was as described in the first pic. PS: Much appreciation for the tips of materials to use. Thumbs up! Edited March 12, 2017 by Grihm Added thank you! Quote
