Members Alexis1234 Posted May 3, 2017 Members Report Posted May 3, 2017 I purchased a Landis 1 harness machine that was not running. I've managed to locate parts, needles,manual , etc and I have it stitching. Problem is, it'll sew a beautiful tight stitch for quite a while, then it'll start looping the threads on the bottom of my work. I have the correct number foot, needle and thread combo and I've played with the tension, etc. Any one familiar with these machines and what I need to adjust? Thanks! Quote
Moderator Wizcrafts Posted May 3, 2017 Moderator Report Posted May 3, 2017 I'm not familiar with your Landis machine. But I am familiar with a lot of other lockstitch machines. Every time I get knots or loops of top thread on the bottom layer, it's because of one of three things. The top thread has jumped or twisted up to the top of the upper tension disks and out of the center spindle area where the spring tension is focused. This results in a complete loss of top tension and the top thread gets dragged all the way down under the material. The bobbin thread is binding inside of, or jamming coming out of the bobbin case spring or enclosure. The top thread got pulled into the bobbin race because it wasn't held back at the start of the sewing run, or because the loose starting thread got drawn down as you sewed past it. Cause number one can happen if the machine vibrates heavily as you sew, or if you are using twisty thread. Number two can be caused by unevenly wound bobbins, or by thread particles under the bobbin spring, or debris along the bobbin race. Number three can be avoided by holding onto the starting threads for at least three stitches, then carefully pulling them away from the bobbin area or throat plate slot. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Yetibelle Posted May 3, 2017 Members Report Posted May 3, 2017 It would be great if you could link a video of it's setup. There are not many good videos of the Landis 1 threading tension and sewing that I have found at least. It takes that huge bullet shuttle setup very cool machine. Quote One day I hope to learn how to sew..... Singer 111W155 - Singer 29-4 - Singer 78-1 - Singer 7-31 - Singer 109w100 - Singer 46W-SV-16 - Adler 20-19 - Cowboy CB-4500
CowboyBob Posted May 3, 2017 Report Posted May 3, 2017 You might want to take the tension plates apart & look for dirt,old thread or grooves on them. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members Alexis1234 Posted May 3, 2017 Author Members Report Posted May 3, 2017 Thank you for the responses. I'm going to play around with the machine in a bit and see if i can get this corrected. I will be posting a link to show how its running/ threaded- even if I'm doing it wrong...Nothing wrong with help from others. When I was researching this machine, I noticed there wasn't much out there and if I can save one from the scrap yard, that would be great. Thanks! Quote
Members Yetibelle Posted May 3, 2017 Members Report Posted May 3, 2017 Well I'm glad it's getting restored. I think they are great looking machines. Quote One day I hope to learn how to sew..... Singer 111W155 - Singer 29-4 - Singer 78-1 - Singer 7-31 - Singer 109w100 - Singer 46W-SV-16 - Adler 20-19 - Cowboy CB-4500
Members Big Sioux Saddlery Posted May 4, 2017 Members Report Posted May 4, 2017 I sewed on a Landis One exclusively for at least 15 years and still use one occasionally. Wiz's advice is pretty solid, as usual. One other thing that is important for this machine to do good and consistent work is for the bobbin to be wound tightly and very evenly. If you did not get a bobbin winder with the machine, you can drill a hole in the side of your bench, chuck the bobbin into a drill and insert the other end of the bobbin into the hole to wind the bobbin. I did this for many years before I found a bobbin winder. I also used a metal lathe when I had access to one for a couple years. Also, the tension plates could have a deep enough groove worn into them that they won't hold tension anymore. If this is the case, just the way the thread comes off the spool could cause enough resistance to mimic the tension from the plates and the machine sews good for a few inches, and then when the thread gets to a different spot on the spool and unwinds more easily, you lose tension and the loops show up on the bottom. As Cowboy Bob mentioned, pull the plates and check for a groove. Quote
Members Alexis1234 Posted May 5, 2017 Author Members Report Posted May 5, 2017 Awesome info! I'm thinking it is the bobbin that's causing the problem... I don't have a winder and have been tediously winding it by hand. I'm going to try the drill, sounds like a great idea. Thank you. Quote
Members tmwp43 Posted May 5, 2017 Members Report Posted May 5, 2017 I have two Landis #1s. One rebuilt and the other being rebuilt. With my first one I got a copy of the owners manual. I have scanned it and can send you a PDF if you'll let me know where to send it. Quote
Members Alexis1234 Posted June 27, 2017 Author Members Report Posted June 27, 2017 I have taken everyone's suggestions and checked and rechecked over and over again It's still randomly looping threads on the bottom... gentleman in Illinois that specializes in Landis 1 looked at my shuttle- it's not a "normal" Landis 1 shuttle- in fact he's never seen one like it before. Absolutely no way to regulate tension on the bobbin- no screws, nothing. I've sent it to him and we'll see what happens. We're thinking that this is the problem. Thank you again for all the help and suggestions! Quote
