From reading other peoples' discussion on this;
I believe there is company in the US called 'Harbor Freight' or something which sells a/p at a good price.
Also; I believe the 1 ton version has a hole in the press bar which matches the Tandy letter adapters for their press
I drilled my HP press hole. Not that hard to do.
George
Tactically Sharp, Inc.
Hialeah, Florida
tacticallysharp.com
"time only is forever"
George
Hialeah, Florida
tacticallysharp.com
The hole is 3/8”. The .5 ton and 1 ton palmgren press on Amazon has a hole already drilled. You just have to drill and tap for a set screw.
Good luck
I have a press from Harbor Freight. It doesn't have a hole yet and it has served me well. I have a set of stamps from Tandy as well as others. If I end up using a stamp repetitively I will definitely want to drill a hole into it but for now I infrequently use stamps so haven't taken the time. If you do a search on youtube there are a bunch of vids showing you what others have done. For example:
Halo-Halo Creations your home of culturally inspired handmade leather, calligraphy, and more.
http://tinyurl.com/hhcreations
  • 3 months later...
That is slick as all get out.
  • 1 month later...
Anyone use their drill press? Just received in a couple sets of letters yesterday and tried it and seems to work ok.
