bikermutt07 Posted May 19, 2017 Author Report Posted May 19, 2017 So, it has alternating presser feet and feed dogs, but no needle feed? Quote
Moderator Wizcrafts Posted May 19, 2017 Moderator Report Posted May 19, 2017 46 minutes ago, bikermutt07 said: So, it has alternating presser feet and feed dogs, but no needle feed? Correct. This is the early Singer walking foot system that is actually only single feed. The outer foot has a leaf spring on the back of it that lets the foot move back with the material, then snaps forward as the feed dog drops below the top of the throat plate. The inside foot and needle only move vertically. I have the same feed on my Singer 42-5. Quote
bikermutt07 Posted May 19, 2017 Author Report Posted May 19, 2017 5 hours ago, Wizcrafts said: Correct. This is the early Singer walking foot system that is actually only single feed. The outer foot has a leaf spring on the back of it that lets the foot move back with the material, then snaps forward as the feed dog drops below the top of the throat plate. The inside foot and needle only move vertically. I have the same feed on my Singer 42-5. These machines are so confusing. Thanks Wiz. Quote
Members Big Sioux Saddlery Posted May 19, 2017 Members Report Posted May 19, 2017 I have seen attempts to sew harness on one of these machines. While they may have the capacity, the results are crude at best. I can't imagine trying to do fine work on one. Visibility is extremely limited by the large foot. I would save the $600 and put it toward a machine better suited for your needs. This is a flatbed machine. For heavy leatherwork, generally a cylinder arm is more useful. Quote
bikermutt07 Posted May 19, 2017 Author Report Posted May 19, 2017 Y'all have convinced me. I had thought it was compound feed, but it's not. I will save up. Quote
