Members Dun Posted May 20, 2017 Members Report Posted May 20, 2017 Where do you prefer to have the shoulder strap attachment points on a briefcase style bag? Middle of the Gussets? even if it fights the flap? On the top flap but supported by a dowel or flat metal bar? diagonal attachment points, on the rear and one the front? or maybe both attachments on the rear? Quote
Members Dun Posted May 23, 2017 Author Members Report Posted May 23, 2017 Just a bump to see if anyone has an opinion, of what they like to make or use on a daily basis. Quote
Contributing Member fredk Posted May 23, 2017 Contributing Member Report Posted May 23, 2017 The only bags I make are variations on the messenger type, from small to medium large. I've just about settled on having the strap mounted via tabs and brass loops on the upper corners of the rear. A bit like the bag in your penultimate photo; but both on the rear, tabs a bit longer, set in from the corners a bit, maybe 1/5 of the bag width. Sometimes I use hooks or snaps so the strap is removable, sometimes not and the strap is permanently attached Quote Al speling misteaks aer all mi own werk..
Members Dun Posted May 23, 2017 Author Members Report Posted May 23, 2017 On 5/23/2017 at 3:28 AM, fredk said: The only bags I make are variations on the messenger type, from small to medium large. I've just about settled on having the strap mounted via tabs and brass loops on the upper corners of the rear. A bit like the bag in your penultimate photo; but both on the rear, tabs a bit longer, set in from the corners a bit, maybe 1/5 of the bag width. Sometimes I use hooks or snaps so the strap is removable, sometimes not and the strap is permanently attached Expand Thanks! Do you find that connection points like that want to bend the bag around you? Quote
Contributing Member fredk Posted May 23, 2017 Contributing Member Report Posted May 23, 2017 Yes, but thats what I and my [few] customers want. We find it a. more comfortable b. easier to get into the bag without the strap getting in the way c. holds the bag closer to the body when turned around, for greater security Quote Al speling misteaks aer all mi own werk..
Members Dun Posted May 23, 2017 Author Members Report Posted May 23, 2017 On 5/23/2017 at 4:38 AM, fredk said: Yes, but thats what I and my [few] customers want. We find it a. more comfortable b. easier to get into the bag without the strap getting in the way c. holds the bag closer to the body when turned around, for greater security Expand Interesting, I like it. Quote
Members DrmCa Posted August 18, 2017 Members Report Posted August 18, 2017 I honestly hate strap attached to the top flap, as then I want to open the flap to reach into the satchel, it drops once un-buckled. Middle of the gusset is my preference. Just 2c. Quote Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Members TxLeather Posted August 18, 2017 Members Report Posted August 18, 2017 My vote goes to the middle of the gussets. Quote
