I went to thread this Adler 167 GK 373 and I was stumped, I haven't seen anything like this and after several searches apparently the interweb hasn't either. I suspect this was a work around but have you seen one like this. Faced with needing parts I wonder what a good source might be in the US. Thanks for any thoughts and input.
595a7dc59b7b9_ChandlerAdler167GK373-52.thumb.jpg.10c842db370b25b886a8168dfa60835b.jpg595a7dd795ee7_ChandlerAdler167GK373-51.thumb.jpg.6e8172c582cb643a560db90eb3f3dc70.jpg
Yes,it original both the single & double needles use the same back plate but the tension post on a single needle is usually on the leftside.
Edited by CowboyBob
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Oh Sweet! So like this?
If your machine was a double needle you would have 2-posts(with the tension discs),one on the right & one on the left,on single needles it's on the left & yours is on the right.It really doesn't matter as long as it's working,which it will but I was just letting you know.
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Thank you sir. I really appreciate your time and expertise.
This is what a standard Adler 167 tension unit looks like:
Uwe (pronounced "OOH-vuh" )
Links: Videos
Then I found this, just like yours:
Links: Videos
Ha, the home-made looking double loop wire actually shows up in the Parts manual for the Adler 167-GK373:
The bottom end of your wire should be inside the corresponding hole in the plate, not sit on top of the plate.
Edited by Uwe
Links: Videos
 I was going by a machine we had on the shelf.
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Ah, yes. I see, this is much better. That spring has been riding there a good long time apparently, judging by the divot it has worn into the plate. Much appreciation.
596008e10660c_ChandlerAdler167GK373-47-1.thumb.jpg.1127f3e406315bd76211bdfcaac3ede9.jpg
