Feed-dog height issues...  After reading the manual(thanks Jimi) the max feed dog height is 4mm and should be used for the thickest leather.
However, my thinnest leather setting has 4mm feed dog height, the middle 3mm FD height and the thickest setting 3.5mm.  See below.  Does anyone know how to change this?
I would atleast like to be able to drop the height to 1mm for the thinnest setting to limit damage to the underside of the leather
Here are some pics.
Thinnest setting
thinSetting01.JPG.2106d29c65f7d321bad1e0ea3476c666.JPGthinSetting02.thumb.JPG.be87d6e5c8df310209b9746d25f34ea9.JPG
Middle setting
midSetting01.thumb.JPG.1e6b25f6c5f92733f43fe8c42eb5709b.JPGmidSetting02.thumb.JPG.85de6b6426013dbe9a82e717b6d3c200.JPG
Thickest setting
thickSetting01.thumb.JPG.35b0ebbed389af49644d6bb28b3b9f37.JPGthickSetting02.thumb.JPG.417046ffb7ca205b7c42c72a4bd71588.JPG
Has anyone had any similar experience?
Thanks for any advice..
Cheers
Alex
i would try and follow that shaft to see what is happening? must be a cam or something on the other end??
you also have a strange looking feed dog on there, i have only seen the 2 teeth type. i dont think they made 4 but i am not sure. this is for rubber soles, the one for leather is a knife. also you can see the difference between a used one and a new one. "someone done the teeth sloping the wrong way in the old one".
DSC_0240.thumb.JPG.9866eaae7948faf45079b69526c69bd2.JPGDSC_0239.thumb.JPG.3598ef08e64d79a7f6923b78539c1643.JPG
Edited by jimi
You can turn it down to the lowest setting,loosen the 2-screws on the collar, turn the pointer to mittel (making sure the shaft doesn't turn), tighten screws & turn down more.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
I know nothing about these machines so my input is probably useless, but that feed dog looks hand-made and might not correspond to the factory dimensions.
9 hours ago, CowboyBob said:
You can turn it down to the lowest setting,loosen the 2-screws on the collar,turn the pointer to mittel(making sure the shaft doesn't turn) ,tighten screws & turn down more.
Thank Bob and everyone who has responded.
Bob: the problem is that the lowest setting is 3mm, which is still too high.  I would like to get it down to 1.5 mm.  Also, at both ends of the stitch length adjuster range (dunn(thin) and dick(thick)) it becomes very stiff.  If I simply change the pointer position so that the lowest setting (3mm) becomes the thinnest (dunn) setting and not the mittel, which it now is, I think it will reduce the range of the adjuster knob.  However, I will try what you suggest.
Jimi:  I will have a look for the cam, maybe it has slipped out of position.  Thin to thick setting on the stitch length adjuster should cause a steady increas in height, which currently it does. Thin is 4mm, mittel is 3 mm and thick is 3.5 mm.  Something is out of kilter...
I am going to either buy or make a new feed dog, which is a cutter.  The current feed dog, is probably for rubber and it probably is homemade.  Here in the old DDR, they become very clever at getting around shortages of goods and parts.
Thanks once again for everyone's suggestions..  It is beginning to sew properly...
Cheers
Alex
Here's the difference I get from high to low.
Edited by CowboyBob
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Hi Bob,
Thanks for taking the time to take the pictures.  The range of depth you have is just what I am looking for, so I think something must be wrong with mine...As you see from mine I only have a range of 1mm and that's in the wrong order...
I see you channel knife is pretty poor.  I am going to make one for myself, since I am making one, then making 2 is no more time.  I can send you that if you wish.
Cheers
Alex
Alex, you could maybe try to loosen this screw also? i think it just blocks the shaft?
thickSetting01.JPG.8e2e142f8c43b543c6cee07093fcf311.thumb.JPG.8b15bfbb3baf832774131e63772bfd85.JPG
if the machine is not bolted to the base you could probably see things better from underneath??
Edited by jimi
ok Jimi, I will give that a go... And  try this weekend... I am a little scared about adjusting, because it does sew already, now that the tension issue is partially sorted....  I buggered up a fur sewing machine that wasn't running quite right by fiddling and i would have been better off leaving it alone... :(:)
I have been trying to find a spare parts diagram, but have had no luck... That would help also to get an idea of what is connected to what and its function.....
Cheers
Alex
Oh i have one of them and they have little arms and shafts that move all over the place:lol: what make was the fur machine?
i would think it difficult to bugger up one of these frobanas as they are solid sods.do you have it bolted to that pine underneath?
