Primosand Report post Posted July 21, 2017 Hi Folks, I'm looking for a little advise before I spend my money. I recently bought a Pfaff 142-6, twin needle upholstery machine that came with a clutch motor. I want to upgrade it with a new servo motor. I'd like to know a couple of things before I spend my money.. 1. 550W or 750W ? I have Consew 226R with a 550W Consew servo motor and a speed reducer pulley set up similar to the way Cowboy or Cobra cylinder arm machines come new. It works great but would a 750W work even better? 2. Does adding a speed reducer pulley add torque (piercing power) at very low speeds? Leather sewing speeds. 3. What particular brands are the best deals (bang for your buck) on a servo motor these days? (are all brands the same?) Check out my new Pfaff 142-6 pictures below. I'm so proud, always wanted a twin needle machine but that clutch motor is down right scary and has to go. What is a perfectly good clutch motor good for in a re-purposed kinda way? I was thinking a polisher for cleaning up vintage sewing machine parts that have a bit of rust. Thanks in advance for any advice you'd care to share. jeff Quote Share this post Link to post Share on other sites
Rockoboy Report post Posted July 22, 2017 I know a bloke who gets his servo motors from China for a very reasonable cost, and he says they are great. They look fine to me, but I am not an expert. I am also hoping to repurpose the clutch motor from my Toyota DT6, after I get one of the Chinese servo motors. I am leaning towards a polisher/burnisher. Quote Share this post Link to post Share on other sites
Constabulary Report post Posted July 22, 2017 (edited) I can only speak for JACK Servo motors. I have two 750W motor + speed reducer in use and I´m very pleased with them very good control and plenty of torque. I sometimes switch my machine heads so I can use 2 motors with 6 - 7 different machines depending on what work I have. I have tried 550W Jack motors and I somehow felt they have a weaker stop brake. So when you have machines with a heavy fly wheel (like Singer 45K or the like) and sew at higher speed the needle seem not to stop at the moment you step of the pedal. I somehow felt the needle still moves a bit when I step off the pedal. So for my purposes I would buy the 750W version again they seem to have a harder / better brake. I´m using theses setups even for "light work" such as binding (Pfaff 345) and zigzag sewing (Singer 307G2) or heavier sewing (Singer 45K, 133K, 111G156) I never had any issues beside the needle positioner does not work in combination with the speed reducers but I figured I do not need the needle positioning at all - I can easily turn off this feature. Some may say this setup (750w + speed reducer) is over powered for some machines but as I said - up to the current day I never had any problems. Edited July 22, 2017 by Constabulary Quote Share this post Link to post Share on other sites
Primosand Report post Posted July 23, 2017 Thanks for the input gentlemen. I've ordered a 750W motor rather than a 550W. I'm going to try it out without a speed reducer or needle position and see how it works. I figure I can add the other items later if needed. Interesting that a speed reducer screws up an add on needle position device. I had not considered that. thanks again for the help. Quote Share this post Link to post Share on other sites
Hockeymender Report post Posted July 23, 2017 For what it's worth I have machines with both a speed reducer and needle positioner and have no difficulties. The motor is a Goldstar 550 watt. I have found the combination of the punching power afforded by the reducer, and the ability to stop with the needle in the down position was just what I need for most of the work I do. Quote Share this post Link to post Share on other sites
CowBoyOUTLAW Report post Posted November 25, 2022 On 7/21/2017 at 10:58 AM, Primosand said: Hi Folks, I'm looking for a little advise before I spend my money. I recently bought a Pfaff 142-6, twin needle upholstery machine that came with a clutch motor. I want to upgrade it with a new servo motor. I'd like to know a couple of things before I spend my money.. 1. 550W or 750W ? I have Consew 226R with a 550W Consew servo motor and a speed reducer pulley set up similar to the way Cowboy or Cobra cylinder arm machines come new. It works great but would a 750W work even better? 2. Does adding a speed reducer pulley add torque (piercing power) at very low speeds? Leather sewing speeds. 3. What particular brands are the best deals (bang for your buck) on a servo motor these days? (are all brands the same?) Check out my new Pfaff 142-6 pictures below. I'm so proud, always wanted a twin needle machine but that clutch motor is down right scary and has to go. What is a perfectly good clutch motor good for in a re-purposed kinda way? I was thinking a polisher for cleaning up vintage sewing machine parts that have a bit of rust. Thanks in advance for any advice you'd care to share. jeff Quote Share this post Link to post Share on other sites
