New to the leather making.  Any tips on what to do better?  Thanks
I'm not an expert on holsters but I think you'll find the holster will loosen up because the stitch line should be closer to the gun.
Any chance of seeing the backside?
with the mag holder, I would have added a back piece to protect the ribs from being dug from the end of the clip
Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
I made it for my cousin about a week ago.   He uses it whenever he goes to ranch.   I'll let him know about the stitches.  Hopefully holster stays snug.   Thanks for the feed back.
I agree with Halitech on the stitch line.  I should work as is for a while with no issues.  You can always add another stitch line inside the existing one to make it last longer.  Also, I would suggest you clean up your belt holes by edging them and then burnishing.  Otherwise, looks good.
Learnleather.com
I agree with the above comments,  but I have to say that I  really like your dye job. I also think you did a good job on your boning - you got a good amount of definition that should help your retention if you tighten up your stitch line.
