Members Leahlovesleather Posted July 29, 2017 Members Report Posted July 29, 2017 Hi, I am new to leathercraft and bought a safety beveller, like the one Tandy sell (see second image). It is great for the first 5 minutes but the blade dulls quickly. I mainly make wallets and small goods. Is it worth sharpening the replaceable blades, or can anyone recommend what they believe would be the best skirver to buy. I was thinking maybe a french skirver like the one in the first image. Quote
Members howie696 Posted July 30, 2017 Members Report Posted July 30, 2017 (edited) Use the shick injector blades they are much better But the best is something like this https://www.etsy.com/uk/listing/257475163/angular-skiving-knife-vergez?ga_order=most_relevant&ga_search_type=all&ga_view_type=gallery&ga_search_query=skiving knife&ref=sr_gallery_2 Edited July 30, 2017 by howie696 Quote
Members Matt S Posted July 30, 2017 Members Report Posted July 30, 2017 Just now, howie696 said: Use the shick injector blades they are much better They are not always available or cheap. In the UK for instance they are more expensive than the 'real' ones. I use a Swann Morton 10a scalpel blade on a no3 handle. Strop or replace the blade as soon as it starts dulling. It took a lot of leather and a lot of four-letter words to learn how to skive and I tried a few different knives. This is very handy, fast and economical. Quote
Members zuludog Posted July 30, 2017 Members Report Posted July 30, 2017 (edited) I made a knife similar to the Blanchard one from an old 25mm hacksaw blade A Japanese craft knife is similar, Search & Surf Google & YouTube for a KIRIDASHI. Also Search YouTube for 'skiving leather'; there are a few videos You could also look at a Japanese Leather Knife. Again Search & Surf to see what it looks like, and how to use it. Videos by 'leathertoolz' are good & useful Both of these can be used to both cut out and skive leather. You can get them at a reasonable price, though as with anything you can pay as much as you want. They are straightforward enough to make from an old hacksaw blade or plane blade The key to any leatherwork is to have very sharp tools. You will need a fine stone; oil-, water/ceramic-, or diamond-, whatever you fancy. Because they have been around for a long time you can often find oil-stones secondhand Make your own strop from oddments of wood & leather, but treat yourself to some proper stropping/honing compound. It's not that expensive, and a bar will last you for years Yes, scalpels are good, I use them on model planes, just Search Google. Matt S has found what suits him, but can I suggest that a number 4 handle (and appropriate blades) might be a better choice for leatherwork? Matt S sums it up - time, practice, try different knives till you settle on what works for you; and be prepared for a fair amount of frustration I use mostly 3 to 3,5mm leather and use a kiridashi and s Japanese knife. If I was using thinner leather I might use something different Remember that if you use one of these types of knives you will need work on a hard smooth surface like a thick sheet of glass, a tile, or a marble slab Edited July 30, 2017 by zuludog Quote
Members Leahlovesleather Posted July 30, 2017 Author Members Report Posted July 30, 2017 I will try the Schik Injector blades. Thanks Howie for the suggestion. I live in Perth too,so hopefullythey aren't expensive here. Do they stay sharp longer? Quote
Members howie696 Posted July 31, 2017 Members Report Posted July 31, 2017 19 hours ago, Leahlovesleather said: I will try the Schik Injector blades. Thanks Howie for the suggestion. I live in Perth too,so hopefullythey aren't expensive here. Do they stay sharp longer? Yes they are a much better blade, then also fit the strap cutters, lace cutters etc Quote
Members teresamwong Posted August 3, 2017 Members Report Posted August 3, 2017 These are good comments. I make handbags. I also use the Tandy skiver pictured in the 1st post. And yes, the blades do wear out after 5 minutes of use. I even bought the better quality ones. I am going to try the Shick Injector blades too. that Tandy skiver has got to be the most un-ergonomic tool ever invented. what were they thinking? I guess they got me to buy it... but it is so awkward to use and horrible to hold. i appreciate the suggestions for the knives above, but I am not good with knives... I do need more of a safety feature. any similar skivers with a handle you can recommend? Teresa Quote Teresa shopmariejay.com
Members teresamwong Posted August 3, 2017 Members Report Posted August 3, 2017 Just saw the previous post about Swann Morton surgical knife. i am going to try this! Thanks! Quote Teresa shopmariejay.com
Members zuludog Posted August 3, 2017 Members Report Posted August 3, 2017 (edited) Swann Morton's website is https://www.swann-moron.com Their USA distributor is http://www.cincinnatisurgical.com Although this website is British it gives you a good idea of the range available http://www.scalpelsandblades.co.uk Have a look at # 4 or # 6B handle and # 25 blades. Or see if there are any taster or starter packs which would give you a handle and one of each type of blade, these are usually good value for money I don't know about USA, but in Britain there are lots of outlets & suppliers. Shop around craft, hobby, and art stores Also search YouTube for 'scalpels and blades' There are several videos Edited August 3, 2017 by zuludog Quote
Members niakulah Posted September 23, 2018 Members Report Posted September 23, 2018 Anyone here actually sharpen or strop the safety skiver blades? If yes, how do you do it? They're pretty tiny to hold on to. Like others I have found they are only sharp for 5 minutes or so.... I'll also try to look for the schick injector blades. Quote
