Members venator Posted August 28, 2017 Members Report Posted August 28, 2017 I was airbrushing dye on to some lifting straps the other day and took a video. Check it out, this is the first coat. Quote
Members Wedgetail Posted August 28, 2017 Members Report Posted August 28, 2017 (edited) Oooh that's a nice red! Wot dat? My airbrush gets a "workout" too (pun intended), good for nice even coats on just about any projects, or for making a nice patina finish. Edited August 28, 2017 by Wedgetail Added quote marks Quote
Members Sanch Posted August 28, 2017 Members Report Posted August 28, 2017 Look up DIY for silent air compressors!!! Min runs as quiet as a refrigerator. Quote
Members venator Posted August 28, 2017 Author Members Report Posted August 28, 2017 10 hours ago, Wedgetail said: Oooh that's a nice red! Wot dat? My airbrush gets a "workout" too (pun intended), good for nice even coats on just about any projects, or for making a nice patina finish. It's the Tandy Crimson waterstain, it's a great red and I prefer using the waterstains through the airbrush when I can. Air brushing is definitely the easiest way to get a nice consistent even coat of dye I find. 5 hours ago, Sanch said: Look up DIY for silent air compressors!!! Min runs as quiet as a refrigerator. I'll take a look, it's not really a big deal though since it's in the garage and it's not like I'm trying to airbrush at 2am. Quote
Members Wedgetail Posted August 28, 2017 Members Report Posted August 28, 2017 Nice thanks mate, I'll give those a go. I'm with you there, water based stuff is both less toxic and thinner... both good qualities for a liquid you intend to atomize. Quote
Members venator Posted August 28, 2017 Author Members Report Posted August 28, 2017 32 minutes ago, Wedgetail said: Nice thanks mate, I'll give those a go. I'm with you there, water based stuff is both less toxic and thinner... both good qualities for a liquid you intend to atomize. Yup, I find with the alcohol dyes too much of it ends up in the air and not enough on the leathers. Plus the waterstains seem to even themselves out a bit whereas alcohol dyes don't. Quote
Members nrk Posted August 28, 2017 Members Report Posted August 28, 2017 6 hours ago, venator said: Air brushing is definitely the easiest way to get a nice consistent even coat of dye I find. hmm.. airbrushing imho gives a very thin top dye coat. deep penetration is possible , for example, when you take a sponge and a dye, and work it into the leather (besides of sinking a piece of leather in a jar of dye ) :). specially 2-3 times. this allows pigments get as much deep as possible into leather. airbrushing is good for decorations, patinas, gradients etc. Quote
Members venator Posted August 28, 2017 Author Members Report Posted August 28, 2017 Well you can soak it with the airbrush too, but like with working it in with a sponge it just gets darker and darker too. I don't find the penetration any worse with the air brush and I do 2-3 coats on each item. Quote
Members Instinctive Posted August 29, 2017 Members Report Posted August 29, 2017 I use the EcoFlo stain as well with good results. Are you thinning the stain for the airbrush? Quote Eric Fisher Fisher Custom Leather "A Retirement Project" https://fishercustomleather.wordpress.com/
Members venator Posted August 29, 2017 Author Members Report Posted August 29, 2017 14 hours ago, WRLC said: I use the EcoFlo stain as well with good results. Are you thinning the stain for the airbrush? No, I find the eco-flow goes on well enough if I use a fairly large diameter. If I try to push it through the tiny airbrush it helps to thin it a bit. I do thin my resoline 50/50 with water to push it through. Quote
