RockyAussie Posted October 24, 2024 Author Report Posted October 24, 2024 @1hpThat is a nice neat looking job and looks a lot better than my effort. Worth the exercise either way though. I think from memory for every 3mm extra in height you move the knob one click to keep the same stitch length. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
1hp Posted October 24, 2024 Report Posted October 24, 2024 thanks for coming up with this great mod! may put some reference marks on the visible side some day. Quote
CdK Posted October 25, 2024 Report Posted October 25, 2024 @RockyAussie I am one of the people that benefits from the sharing of your modification. I used a square file and some elbow grease to create the additional grooves. The ball detent can be a booger to refit and sticky grease and a knife helped to reinstall it. When I was refitting the plastic ball onto the threaded rod it split and not having the same size ball I came up with what I had in my collection. An adapter was fabricated using a bolt that screwed into the ball. The added mass has the advantage that the lever will drop down if not held in place so no forgetting to return the lever after back stitching. The length of the adapter is sufficient in length and I tapped it deep enough to pinch the "C" shape when tightened down so it doubles as a locknut. Quote Leather work machines I own: Thor 1341, Thor 441, LSZ-1 clone, 801 bell skiver, Tinker's Delight Shoe Patcher. (Tippmann Boss was re-homed.)
RockyAussie Posted October 26, 2024 Author Report Posted October 26, 2024 Good looking end result there @CdK every little bit helps. Magnet attached screw driver rack I assume? Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members dikman Posted October 26, 2024 Members Report Posted October 26, 2024 It seems to me that your idea of drilling/countersinking holes along the travel path of the detent ball would be easier than cutting grooves? I can't think of any downside to doing it that way. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
CdK Posted October 27, 2024 Report Posted October 27, 2024 19 hours ago, RockyAussie said: Good looking end result there @CdK every little bit helps. Magnet attached screw driver rack I assume? Tried that but the cat kept knocking it off, 3M double sided tape now anchors it in place. I do use coin magnets to hold other bits close at hand as I cut down the pedestal to minimums to save space in my work space. The maximum foot print of my machines are determined by the heavy metal base and nothing more, must be the Dutch DNA in me, use as little floor space as necessary. Quote Leather work machines I own: Thor 1341, Thor 441, LSZ-1 clone, 801 bell skiver, Tinker's Delight Shoe Patcher. (Tippmann Boss was re-homed.)
